It is currently Thu Oct 18, 2018 11:28 am
 Post subject: Parts wanted.
PostPosted: Sun Nov 05, 2017 1:14 pm
Hi am after some parts for my dolly I need rear view mirror wood capping rear drivers side 2 outer sills fuel pump 2 float chamber gaskets rocker cover gasket for sprint cheers steve
 Post subject: Re: Parts
PostPosted: Sun Nov 05, 2017 6:43 pm
Club spares are the place for cills:
viewtopic.php?f=13&t=20146
A pair are £80.00 inc delivery to UK address.
I have a quantity of float chamber lid gaskets and rocker cover gaskets, £3.00 for a pair for the former, £8.00 for the latter inc postage.
PS: You might need to ask admin to give you access to the members' area to read the link I gave...
 Post subject: Re: Parts wanted.
PostPosted: Mon Nov 06, 2017 7:09 am
TDC West Yorks Area Organiser
I've moved the thread here because it was a "wanted" one.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Mon Nov 06, 2017 3:08 pm
Hi am after some parts for my dolly ... fuel pump ... cheers steve
Hi Steve, There are 2 types of fuel pump. Early and late.
Here is something I wrote about it recently.
search.php?keywords=fuel+pump&terms=all ... mit=Search
HTH,
PostPosted: Tue Nov 07, 2017 6:46 am
Hi Tony my dolly I have is a 76 1850 but it's been turned into a sprint the only difference is that I have yet put in the overdrive box the sprint engine that is in the car I have know idea what year it is cheers Steve
PostPosted: Tue Nov 07, 2017 6:00 pm
The change point on fuel pumps was 1977 (ish) but if engine swaps have been done its a bit indeterminate.
The best thing to do is have a look at where the pump mounts to the block. If there is a plastic spacer you need the later style pump.
The spacer looks like this ...
https://www.rimmerbros.co.uk/Item--i-UKC8523
HTH,
PostPosted: Tue Nov 07, 2017 6:27 pm
HTH,
If there's a plastic spacer, he can use either pump and just not use the spacer if he gets a short arm pump. If there is no plastic spacer, he either needs the short arm pump, or to source a spacer with the long arm one if that is what he can obtain...
PostPosted: Tue Nov 07, 2017 8:35 pm
Thanks that's really helpful cheers
