It is currently Thu Sep 20, 2018 1:13 am
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Thu Jan 18, 2018 12:11 am
Anybody have a set of old style rear wheel arch panels, the sort that cover this area:
My car has had them fitted in the past but it's an utterly dire job (riveted on top of the original arches I suspect!) and the whole lot is rotting out badly. The TDC panels don't cover enough area above the lip and quite a bit of fabrication would be required. I'd also consider the same bits cut from a parts car as long as they are in good enough nick that the TDC panels could sort them, its the prior bodgery that has caused them to rot in odd places rather than the usual arch lip that is causing me problems!
1976 Triumph Dolomite 1850HL "Trevor, the Tenaciously Terrible Triumph" - Off the road for many years, currently being fixed.
1977 Triumph Dolomite 1300 "Daisy, the Dilapidated Dolomite of Disaster" - On the road, still a dilapidated disaster.
2005 Honda Civic 1.6i Exec "The Honda" - Broken, rear brakes are seized on...
