It is currently Sun Aug 19, 2018 8:00 am
 Post subject: 1850 early water pump
PostPosted: Sun Apr 15, 2018 11:41 am
This is for the '73 1850 auto project, before I get a refurb one from HRS, anyone have one they want to move on?
PostPosted: Sun Apr 15, 2018 10:15 pm
Do you mean the one with the six small vanes? If so are you certain as the later 6v are more efficient... The two types have different covers; do you know what you have fitted?
PostPosted: Mon Apr 16, 2018 7:28 am
Fair point Alun, I'd best not assume anything about this car and physically check what's been installed first, BRB.
PostPosted: Sun Apr 22, 2018 4:33 pm
6 blade as it turns out, I've seen ones with a 2 cast on them but this has ST1, correct early 1850 type I'd guess.
PostPosted: Sun Apr 22, 2018 4:48 pm
Don't know, show me a side view...
PostPosted: Sun Apr 22, 2018 5:24 pm
Idly wondering about rebuilding it now but here goes for the side view.
PostPosted: Sun Apr 22, 2018 6:09 pm
Yes, that's an early 6v; it's the depth of the spigot between blades and bolt head that tells you.
Brian Kitley always advocated keeping water pumps, jackshafts and dizzy drives as a used matched set as they will have worn sympathetically with each other.
The gears on that look good, so, yes, I'd rebuild it.
I had my last repair kits from www.socspares.co.uk :buying two worked out about £15-16 each delivered, 2/3 of HRS price and just as good quality.
PostPosted: Sun Apr 22, 2018 6:41 pm
Ah, thanks Alun, so the vanes are a bit taller on the later 6 valve, useful to know and I agree with keeping matched gear sets as logical. I've disassembled it and will post something in the right place for opinion on rebuilding it.
cron
