It is currently Mon Nov 19, 2018 10:04 pm
PostPosted: Wed Apr 18, 2018 1:33 pm
hi all
started doing the brakes and guess what,brake totally stiff,no movement in peddle
so if made a tool to remove the back plate from the front dome
the back plate a has rusted and allowed the plastic inner to push thru
so has anyone got a back plate? its got 4 bolts fitting to bulkhead
thanks nic tt
Dolomite 1300,1980`V`reg in british racing brown(russet),3.63 diff with 21t speedo pinion,95%poly`d,HL clocks,standard wheels with SE covers wrapt in 175 70 13,mot`d 19-09-2014,been off the since 1990,(july2017) stainless steel exhaust 3-piece.
Dolomite 1300,1977(tax free 1-1-1977),`R`reg in carmine red,bog standard including rust :shock: last time on road 6-2005
PostPosted: Mon Apr 23, 2018 5:20 pm
managed to get to middle piece out today and nothing broke :shock: all in bits,seals look like new just never used hense why it seized it self causing no pedal/stiff to push
so for now not i great need for the back panel.....thanks for now
PostPosted: Wed Apr 25, 2018 12:03 pm
I have a complete servo for a 1300 Dolomite if you are interested,
Malcolm
