It is currently Thu Jul 19, 2018 5:19 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Jun 22, 2018 2:05 pm
hi all
can anyone help,my red dolly need a drivers side rear suspension body mount(triangle shaped)
here a picture of mine,,,very rusty and flakey
il even take a salvaged part,,anything got to be better then mine
thanks nic tt
Dolomite 1300,1980`V`reg in british racing brown(russet),3.63 diff with 21t speedo pinion,95%poly`d,HL clocks,standard wheels with SE covers wrapt in 175 70 13,mot`d 19-09-2014,been off the since 1990,(july2017) stainless steel exhaust 3-piece.
Dolomite 1300,1977(tax free 1-1-1977),`R`reg in carmine red,bog standard including rust :shock: last time on road 6-2005
PostPosted: Sat Jun 23, 2018 4:39 pm
Hi Nic, It looks like this part is available as a spare. On page 2C 06R of the late parts book it lists 817448 and 817449 " Bracket, mounting, rear suspension LH /RH " . If this is the correct part it looks like it is bolted and welded to the floor pan. :shock:
I couldn't immediatly find a supplier so it may be that you would have to find a scrap shell and cut one off.
Good luck with it,
PostPosted: Sat Jun 23, 2018 11:59 pm
I'll have a look at my 2 scrap shells on Monday Nic, on 1, I think the floor has receeded in this area but the other might be ok. I'll get back to you, one way or the other!
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Sun Jun 24, 2018 1:49 pm
yes please carledo,nice one
il even take extra floor if its easier to cut out,,il wait for your reply
thanks nic tt
PostPosted: Mon Jun 25, 2018 4:01 pm
I'm sorry Nic but it looks like you are out of luck here, one of mine is rotten, worse than yours, and the other has been cut through when I removed an entire quarter for Rob MacGregors Sprint racer and a chunk is missing. The N/S is intact but that's no comfort to you!
Fitchetts have quite a large stock of Dolomite panels and odds and ends that they don't advertise, its worth giving them a bell with the part number quoted above, you might get lucky!
PostPosted: Mon Jun 25, 2018 7:02 pm
thanks for looking steve
so,i`m still looking
PostPosted: Tue Jun 26, 2018 1:56 pm
no go at td fitchetts
PostPosted: Sun Jul 01, 2018 3:51 pm
I've just purchased a shell that should have a good rear mount. I will not be collecting it for a few weeks plus I need to check the car I'm repairing doesn't need it, so as long as you're not in too much of a rush I could have one available.
Modified Dolomite Sprint MSO 662P
PostPosted: Mon Jul 02, 2018 7:25 pm
hi
thats ok,,in no no no no rush,just getting the parts together first before starting the weld-a-thon :bluewave: luv it
good luck with your car/body
cron
