It is currently Thu Sep 20, 2018 6:47 pm
PostPosted: Fri Jul 13, 2018 8:18 pm
I need a 21 tooth replacement speedo pinion drive gear (supposedly green) if anyone has a decent used one or a NOS one hanging around anywhere?
I think that one has had it!
Cheers, Sam
http://yorkshire-spitfire.blogspot.com/
PostPosted: Fri Jul 13, 2018 8:41 pm
Call Overdrive Repair Services in Sheffield.
PostPosted: Fri Jul 13, 2018 10:06 pm
Sam should have noted that this gear is for a BW65 Auto trans, so unlikely that O/D services would even list it.
AS I said on your resto thread Sam, try Harvey of this Forum, he's an Auto specialist!
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Fri Jul 13, 2018 10:14 pm
I have a green one, but it only has 19 more vertically orientated teeth.
I have a 21 toothed diagonally cut one, but it is black.
PostPosted: Fri Jul 13, 2018 11:36 pm
Reckon the number and shape of teeth is probably more critcal than the colour!
PostPosted: Sat Jul 14, 2018 1:18 pm
Cheers, Sam
I did PM you but i've worked out where is was in the box! I have pulled the gear from my spare sprint / 1850 box and it's 21 tooth but Red in colour.
Rich..
1981 Dolomite 1500 Auto
1971 Toledo 4 door
PostPosted: Thu Jul 19, 2018 7:47 am
Still on the hunt for a 21 tooth pinion gear.... both of the ones generously pulled from autoboxes by people on here (THANKS!) turned out to be 22 tooth. I'm going to use one of those to get me going and I'll check the speedo against GPS. In theory it should be less than 5% difference, but if I get the chance of a 21 tooth one I'd use that.
PostPosted: Thu Jul 19, 2018 9:28 am
I have a number of spare BW 65 boxes in the shed, I'll have a look this weekend
the colour is for identification purposes, I have found that the extension housing sometimes has a red or green dab of paint on it which refers to the colour of the speedo drive.
Malcolm
PostPosted: Thu Jul 19, 2018 9:53 am
Malcolm
Thanks Malcolm, much appreciated.
PostPosted: Thu Jul 19, 2018 12:21 pm
Hmmmm, yes it may be worth trying him....... :lol:
I have got a Dolomite BW65 here, I'll go see if it has the speedo driven gear in it, and if so what colour it is.
PostPosted: Thu Jul 19, 2018 12:37 pm
Much appreciated, thanks
PostPosted: Thu Jul 19, 2018 12:51 pm
I have a Dolomite 011 series BW65, it has a driven gear in it, I removed it, it is green, oh, and it has, let me see, oh yes, 21 teeth.....
Did you like the way I built up the suspense there?.....
