It is currently Thu Sep 20, 2018 6:02 pm
PostPosted: Tue Jul 31, 2018 10:54 am
Hi All,
I'm after an early 1850 thermostat housing, but I don't mind if the thin pipe on the top is broken/leaking/snapped/whatever (as I intend to remove that bit anyway!)
Cheers,
Sam
http://yorkshire-spitfire.blogspot.com/
 Post subject: Hmm…...
PostPosted: Fri Aug 03, 2018 8:24 am
Why are you going to remove the bleed pipe Sam?
PostPosted: Fri Aug 03, 2018 8:31 am
I plan on re-locating the header tank to the OS of the vehicle. As a result what I want to do is remove the pipe, tap the housing and screw in a 90 deg bsp-> 10mm hose adapter.
The "new" tank I have has a 10mm fitting for the overflow, so rather than having an 8mm-10mm adapter in line I'd like to use 10mm ID pipe all the way.
So it kinda solves 2 problems at once for me - the size and direction of the fitting.
PostPosted: Fri Aug 03, 2018 4:56 pm
I have one with a slightly corroded end to the bleed pipe amongst Jon Tilson's things. £3.95 postage, plus what you think it's worth. Cheque to Mrs T...you know the score...
 Post subject: Yes,....
PostPosted: Sat Aug 04, 2018 9:28 am
I had thought you were contemplating something like that.
Are you going to increase the size of the (pin) hole in the thermostat housing?
When I looked at fitting a header tank I discounted the offside because of space limitations
even though such a location could make the hose routing easier.
