It is currently Sun Nov 18, 2018 2:14 am
 Post subject: Distributor needed!
PostPosted: Mon Aug 13, 2018 9:27 pm
Good evening all, this is my first post and I’m a novice at forums so please be gentle lol!! I have recently come into the possession of a Robinhood S7 I know it’s not a triumph! However it has a dolomite sprint engine inside it, the previous owner took out the distributor and was going to convert it, however in the 15yrs of it sitting doing nothing the distributor is missing!! I was hoping that someone on here might have an idea of where I can look, Rimmer Bros do not have any in stock, I’ve also tried Ignition Car Parts uk which also drew a blank! If anyone can help I’d be ever so greatful, many thanks Karl
 Post subject: Re: Distributor needed!
PostPosted: Mon Aug 13, 2018 11:18 pm
Hi Karl, welcome!
I may be able to find you a distributor, I definitely have a couple needing repair to the mounting points, but may also have an intact one too....
PostPosted: Tue Aug 14, 2018 5:38 am
TDC West Yorks Area Organiser
I've moved your thread here because it is clearly a "wanted" thread. Which distributor do you need. Most Dollies had the Lucas except the 1850 which has a Delco.
Welcome to the forum.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
2004 Volkswagen Polo Twist (PK54 JYG - a new project car)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Tue Aug 14, 2018 7:50 am
Wow, thank you for the replies, ok without sounding like too much of an idiot, I can only repeat what I’ve been told, the engine is a 1998cc 16v sprint engine circa 1977 as is on the V5, I hope that helps?
PostPosted: Tue Aug 14, 2018 11:35 am
You will need a Lucas 44D4 dizzy for the Sprint engine. This uses the same points and condesner as the Lucas 45D4 which was fitted to the 1300 & 1550 engined Dollies.
PostPosted: Tue Aug 14, 2018 6:58 pm
Thanks again, well after further investigation, as most of you will probably know the dolomite sprint only went up to 1850cc, it was the Triumph TR7 that had the 1998cc engine in it!!!
PostPosted: Tue Aug 14, 2018 7:23 pm
Dolly sprint engines are 1998 cc :) :)
1977 Flamenco sprint (VGY NOW TAX AND MOT FREE :D )
PostPosted: Tue Aug 14, 2018 7:53 pm
Hi Karl,
Probably safest to take some under 'hood' :wink: pictures and post on here to determine the engine type before splashing any cash.
PostPosted: Wed Aug 15, 2018 5:38 am
This might help:
1850/TR7
Sprint
PostPosted: Wed Aug 15, 2018 11:29 am
Image I’ll need to take a better photo, this pic was already in my phone, I’ll update later, thanks for all your help and advice so far 👍🏼
PostPosted: Mon Sep 03, 2018 7:21 pm
Thank you all for your help, one Dizzy found and delivered, here’s hoping I can get her running 👍🏼
PostPosted: Mon Sep 03, 2018 9:01 pm
With Weber carbs and a tubular exhaust manifold, that is going to absolutely fly when you get it running properly. I wonder if the cam has been changed too.
I had one of these on order in 1989 and I had stripped an 1850 donor and painted up all the parts for it. Trouble was Robin Hood were inundated with orders, I got fed up waiting for the kit to arrive and asked for my deposit back. I sold some of the parts to a chap locally who had received his kit and the chassis was literally 2 x 1" box section bent in a vice, so I was quite pleased I gave up on mine. I understand that the later kits were much better.
