It is currently Thu Jul 19, 2018 3:41 am
 Post subject: Handbrake rubber grommet
PostPosted: Thu Feb 09, 2017 2:40 pm
Noticing that both grommets that prevent the handbrake cable from chafing in their channel (behind the gbox and above the propshaft) are both gone. To avoid having to dismantle the cables I suppose a fuel pipe cut alongside can be inserted and then taped? Or is there a better fix?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
PostPosted: Thu Feb 09, 2017 3:18 pm
TDC Staffs Area Organiser
You could always use an open grommet, cut in much the same way. This will have a good lip on to hold it in position.
1961 Chevrolet Corvair Greenbrier
2015 BMW 118d Sport
 Post subject: Or
PostPosted: Fri Feb 10, 2017 9:42 am
Better still,
brand new grommets, remade in nylon 66, very much superior to the originals,
are available exclusively from TDC spares.
missed a comma!
cron
