It is currently Fri Nov 16, 2018 5:47 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Tue Dec 06, 2011 11:56 am
Site Admin
Site Admin
Please use list as a guide only, we are currently in the process of revamping our stock list. More details soon.
This is a list of items which are usually stocked, although we cannot guarantee that everything is in stock all the time. Ordering details at the end of the list below.
Sprint Items
Bodywork - Coachlines Black, Silver, Gold OE Pattern Remanufactured
£28.99
Bodywork - OE Early Sprint Nose Badge ZKC0375 £19.99
Bodywork - OE Late Sprint Boot Badge ZKC3052 £19.99
Braking - Brake Shoes OE £16.99
Braking - Front Brake Hose £8.99
Braking - Load Sensing Valve Seals (Excludes Dust Cover) £6.99
Braking - Servo Reconditioned & Exchange £135.99#
Braking - Servo Surcharge £20.00
Carburetion - Air Filter Hose Support Bracket Uprated £P.O.A
Carburetion - Alloy Carburettor Mounts 1.75" Pair £67.99
Carburetion - Gaskets For 1.75" Alloy Mounts 158871 AUC4279 Pair
£2.79
Carburetion - Alloy Carburettor Mounts 2" Pair £69.99
Carburetion - Gaskets For 2"Alloy Carb AUD4866 (each) £1.29
Carburetion - O’Rings Std For Alloy Mounts Pair £1.99
Carburetion - O’Rings Viton For Alloy Mounts Pair £5.99
Carburetion - SU Air Filter Gasket 158712 JZX1324 £1.39
Carburetion - SU Solid Butterfly 503817 WZX1321 £8.99
Carburetion - SU Std Jet Front AUD9106 GSU422 £16.99
Carburetion - SU Std Jet Rear AUD9105 GSU421 £16.99
Carburetion - SU Waxstat to Std Jet Conversion Linkage (Each) JZX1307
£2.99
Clutch - Gearbox Cross shaft Remanufactured £45.99
Clutch - Master Cylinder Stainless Sleeved £85.00#
Clutch - Seal Kit Slave Cylinder 52235 SSB627 £6.49
Clutch - Slave Cylinder Stainless Sleeved & Std Piston £29.99#
Clutch - Slave Cylinder Stainless Sleeved & Brass Piston£45.99#
Clutch - Slave Cylinder Brass Piston £15.99
Cooling - Bypass Tube Brass Electric Conversion £19.99
Cooling - Bypass Tube Brass Std £19.99
Cooling - Bypass Tube O’Rings Pair £1.99
Cooling - Fanbelt Kenlowe Fan £4.69
Cooling - Fanbelt Standard Fan £4.69
Cooling - Hose Bottom £12.99
Cooling - Hose Heater £7.99
Cooling - Hose Top LH Large £12.99
Cooling - Hose Top RH Small £9.99
Cooling - Thermostat 82 Deg Recommended £4.99
Cooling - Thermostat 88 Deg £4.99
Cooling - Thermostat Gasket £0.59
Cooling - Water Pump Bung - Electric Conversion £29.99
Cooling - Water Pump Bung O’Rings Pair £2.29
Electrical - Alternator Recon No Surcharge £47.99
Engine - Alloy Spark Plug Tubes £59.99
Engine - Stainless Steel Rocker Cover Allen Key Bolts £6.99
Exhaust - Sprint Sports Mounting Bobbin £2.99
Filtration Air Filter £9.99
Filtration Oil Filter Cartridge £4.99
Filtration Oil Filter Spin On £5.99
Gaskets - Headgasket Std AX540 £NCA
Gaskets - Headgasket +.020 Thicker BK760 £NCA
Gaskets - Headgasket Set Std Excludes Valve Guide Oil Seals £ NCA
Gaskets - Inlet Manifold Gasket JA813 £ NCA
Gaskets - Rocker Cover Gasket £ NCA
Gaskets - Sump Gasket JH469 £ NCA
Ignition - Alternative Ignition Set, Leads, Cap R’arm £42.99
Ignition - Alternative Lead Set £31.99
Ignition - Alternative Dist Cap £8.49
Ignition - Alternative R’arm £4.99
Ignition - Distributor Cap OE Pattern Remanufactured £23.99
Ignition - HT Lead Set OE Pattern Remanufactured £32.99
Ignition - R’Arm OE Pattern Remanufactured £21.99
Ignition - Condenser £4.79
Ignition - Points £2.89
Ignition - Rotor Arm (Alternative Fits Original Cap) £8.99
Ignition - Spark Plugs Cool Running OE Spec £6.99
Ignition - Spark Plugs Set Of 4 £8.99
Service - Kit Std Oil Filter, Air Filter, Spark Plugs, Condenser, Points £32.99
1850 Items
Braking - Brake Shoes 76 On £16.99
Braking - Rear Brake Hose £10.29
Carburetion - Alloy Carburettor Mounts UKC4717 Pair £81.99
Carburetion - Gaskets For Alloy Mounts (each) £1.29
Clutch - Master Cylinder Stainless Sleeved £NCA
Clutch - Master Cylinder Std £32.99#
Clutch - Master Cylinder Surcharge £15.00
Clutch - Seal Kit Slave Cylinder 51373 SP4190 £4.49
Clutch - Slave Cylinder Stainless Sleeved & Brass Piston £45.99#
Cooling - Fanbelt Standard Fan £4.99
Cooling - Hose Top LH Large £10.99
Cooling - Thermostat 82 Deg Recommended £4.89
Cooling - Thermostat 88 Deg £4.89
Filtration Air Filter Stromberg Carb (Each x2 Required) £8.99
Filtration Air Filter SU Carb (Each x2 Required) £8.99
Filtration Oil Filter Spin On £5.79
Ignition - Distributor Cap £8.49
Ignition - Points £3.99
Ignition - Rotor Arm £4.99
Ignition - Spark Plugs Set Of 4 £9.99
Service - Kit Std Oil Filter, Air Filter, Spark Plugs, Condenser, Points £41.99
1300 & 1500 Items
Bodywork - Coachlines 1500 SE Silver, OE Pattern Remanufactured
£65.99
Braking - Brake Shoes 1500HL 76 On £16.99
Braking - Wheel Cylinder 1300 £10.99
Braking - Wheel Cylinder 1500 £10.99
Carburetion - Linkage Rod End Connection (Each) £1.99
Clutch - Seal Kit Slave Cyl 1300 & 1500 76 to 81 £4.49
Filtration Oil Filter Spin On £6.79
Filtration Air Filter SU Single £8.99
Filtration Air Filter SU Carb Dolomite (Each x2 Required) £8.99
Filtration Air Filter SU Carb 1500TC (Each x2 Required) £8.99
Ignition - Condenser RWD £4.79
Ignition - Points RWD £2.89
Ignition - Condenser FWD £4.29
Ignition - Points FWD £2.89
Ignition - Distributor Cap £5.49
Ignition - Rotor Arm £2.99
All Categories
Bodywork - Badge Boot Triumph Late ZKC3062 £22.99
Bodywork - Badge Nose Laurel Wreath Late Black & Gold £24.99
Offside outer cill £50.00 delivered £30.00 if collected
Nearside outer cill £50.00 delivered £30.00 if collected
A pair of outer cills are £80.00 delivered, £60.00 if collected
Offside Cill Reinforcer panels £80.00 delivered, £60.00 if collected
Nearside Cill Reinforcer panels £80.00 delivered, £60.00 if collected
A pair of cill reinforcers are £140.00 delivered, £120.00 if collected
Offside inner cill £40.00 delivered, £20.00 if collected.
Nearside inner cill £40.00 delivered, £20.00 if collected
A pair of inner cills are £60.00 delivered, £40.00 if collected.
NS front door repair panel £31.00
OS front door repair panel £31.00
NS rear door repair panel £31.00
OS rear door repair panel £31.00
Due to increase in costs, there is now no discount for orders for
multiple door panels
NS front wing repair £46.00
OS front wing repair £46.00
NS Boot floor repair £72.00
OS Boot floor repair £72.00
NS Chassis leg £85.00
OS chassis leg £85.00
NS front footwell £95.00
OS front footwell £95.00
NS outer headlamp mounting panel £40.00
OS outer headlamp mounting panel £40.00
NS inner front valance repair £52.00
OS inner front valance repair £52.00
NS inner front valance repair (Toledo/Dolomite 1300/Dolomite 1500 non-HL) £52.00
OS inner front valance repair (Toledo/Dolomite 1300/Dolomite 1500 non-HL) £52.00
NS front subframe mounting kit £48.00
OS front subframe mounting kit £48.00
NS outer front valance upper repair (inc bonnet hinge mount) £40.00
OS outer front valance upper repair (inc bonnet hinge mount) £40.00
NS rear wing repair £60.00
OS rear wing repair £60.00
NS rear wing repair (Toledo/1300fwd) £57.50
OS rear wing repair (Toledo/1300fwd) £57.50
NS rear wheel arch strip £28.00
OS rear wheel arch strip £28.00
NS GRP eyebrow £45.00
OS GRP eyebrow £45.00
NS GRP front wing £145.00 (collect price £115.00)
OS GRP front wing £145.00 (collect price £115.00)
GRP full front outer valance £175.00 (collect price £145.00)
1300 FWD front valance £112.00 (collect price £98.00)
GRP transmission tunnel (manual only, Sprint version) £80.00
collected £95.00 delivered
Rear arch front lip £38.00
Braking - Calipers All Models - Single £63.99#
Braking - Calipers All Models – Pair £126.99#
Braking - Master Cyl Single Line Std £85.00#
Braking - Master Cyl Single Line Uprated £75.99#
Braking - Master Cyl Tandem Line Std £105.00#
Braking - Pads All Models £NCA
Braking - Seal Kit Calliper 51561 SP2697 (Single) £5.99
Braking - Seal Kit Master Cyl Tandem £12.99
Braking - Seal Kit Master Cyl Tandem LHD & Early Sprint £9.99
Braking – Seal Kit Master Cyl Single Line £6.49
Braking - Seal Kit Wheel Cyl Rear 1300 76 to 81 £4.49
Braking - Seal Kit Wheel Cyl Rear 1500 76 to 91 51413 SP2369 (Single)
£3.99
Braking - Seal Kit Wheel Cyl Rear 1500 78 on 1850 76 on & Sprint
(Single) £3.99
Braking - Stop Light Switch £5.99
Carburetion - Choke Cable Twist Lock Alternative £7.99
Carburetion - Choke Cable Pull Lock Alternative £7.99
Carburetion - SU Butterfly Splay Screw 108349 AUC1358 £0.89
Carburetion - SU Float Chamber Gasket 511738 AUC8459 £0.99
Carburetion - SU Jet Gland Seal AUD2194 £0.79
Carburetion - SU Jet Adjusting (each) £3.49
Carburetion - SU Choke Cable Connection (Centre Hole) £3.99
Carburetion - SU Choke Cable Connection (End Hole) £3.99
Carburetion – SU Needle Valve Kits WZX1100 (each) £9.79
Clutch - Seal Kit Master Cyl All Models 50515 SP1963 £6.49
Clutch - Seal Kit Slave Cylinder 1850 51373 SP4190 £4.49
Clutch - Seal Kit Slave Cylinder Sprint 52235 SSB627 £6.49
Cooling - Rad Cap 13lb £4.69
Cooling - Rad Cap 15lb (Uprated Alternative) £4.99
Electrical - Alternator Wiring Plug Kit £4.99
Electrical - Flasher Unit Uprated Electronic £16.99
Electrical - Fuses 17/35 Pack 3 £1.29
Electrical - Oil Pressure Switch £5.99
Electrical - Overdrive Gearbox Lever Wires £8.99
Electrical - Thermal Transmitter £8.99
Electrical - Voltage Stabiliser Uprated Electronic £17.99#
Electrical - Washer Pump Alternative £8.99
1500 Starter Motor £100.00 strict exchange policy only
1850 Starter Motor £100.00 strict exchange policy only
Sprint Starter Motor £100.00 strict exchange policy only
Alternators £tba
Steering Rack £55.00 strict exchange policy
Strg & Suspension - Balljoint Gaitors Lower (Each) £2.99
Strg & Suspension - Balljoint Gaitors Upper (Each) £2.99
Strg & Suspension - Balljoint Lower Front LH or RH £45.99#
Strg & Suspension - Balljoint Upper Front LH & RH £45.99#
Strg & Suspension - Bush Steering Column Bulkhead £5.99
Strg & Suspension - Steering Rack Gaitors (Each) £5.49
Strg & Suspension - Stub Axles Ford Spec Remanufactured Pair £99.99
Strg & Suspension - Stub Axles Std Spec Remanufactured Pair £99.99
Strg & Suspension - Track Rod End (Each) £10.99
Strg & Suspension - Track Rod End Gaitors (Each) £2.99
Strg & Suspension - Upper Balljoint Overhaul Kit £29.99
Strg & Suspension - Upper Steering Coupling FWD Only - Exchange
£27.99
Strg & Suspension - Wheel Bearing Kit £15.99
Strg & Suspension - Tie Bars Adjustable (Pair) £87.99#
Strg & Suspension - Steering Rack Mounts Polly (Pair) £11.99
Universal - Nyloc Nuts Bag 10 1/4" £1.99
Universal - Nyloc Nuts Bag 10 5/16" £2.19
Universal - Nyloc Nuts Bag 10 3/8" £2.29
Universal - Nyloc Nuts Bag 10 1/2" £2.39
TDC Stainless Steel Exhaust Systems (ORDERING DETAILS FOR THESE SYSTEMS IN MEMBERS-ONLY SECTION)
PRICES LISTED INCLUDE VAT AT 20% & DELIVERY WITHIN THE UK
TRIUMPH 1300 FWD 1966-1970 TH 51, 53, 52 £325.00
TRIUMPH 1300 TC 1966-1970 TH 89, 90, 52 £335.00
TRIUMPH 1500 FWD 1970-1973 TH 137, 138, 139 £315.00
TRIUMPH TOLEDO 1973-1975 TH 103, 179, 162 £310.00
TRIUMPH 1500TC 1973-1976 TH 103, 179, 147 £325.00
TRIUMPH DOLOMITE 1300 1976-1981 TH 103, 179, 175 £330.00
TRIUMPH DOLOMITE 1500/1500HL 1976-1981 TH153, 178, 155 £315.00
TRIUMPH DOLOMITE 1854cc
Man non-overdrive/auto 1972-1975 TH 127, 181, 166 £280.00
Man overdrive 1972-1975 TH 127, 180, 166 £265.00
(Transverse box) 1975-1976 TH 127, 167, 168, 155 £300.00
TRIUMPH DOLOMITE 1850HL 1976-1981 TH 127, 167, 168, 155 £300.00
TRIUMPH DOLOMITE SPRINT std system 1973-1981 TH140, 141, 142, 143 £499.00
SHIPPING
Parts can only be supplied to Triumph Dolomite Club Members. Please Quote your Membership
Number when ordering.
Prices include carriage and packaging to mainland UK locations.
Continental Europe carriage will be charged at 15% of the order value.
Rest Of World carriage will be charged at 25% of the order value.
#Exchange Items – We require your old units to be returned to ensure our reconditioning programme
can operate. The prices quoted include carriage to yourselves. The return carriage cost will need to be
met by the club member.
TO ORDER
Ordering details are in the Members-only section and in Dolly Mixture, the Triumph Dolomite Club's magazine. If you require access to the Members-only sections see this viewtopic.php?f=4&t=18
Club membership costs just £27 for one year or £50 for two years. See viewtopic.php?f=4&t=2412 for details.
PostPosted: Sat Aug 22, 2015 2:28 pm
TDC N Ireland Area Organiser
OS rear wing repair £45.00
is this the repair panel that comes from the lower quarter panel to the boot floor lip..
if it is then how much would it be to post to Belfast northern Ireland U.K.
thank you /..... :)
PostPosted: Sat Aug 22, 2015 5:03 pm
The price list is a little historic, the panel is now £60.00 delivered to Club members mainland addresses.
Unfortunately, for economy, we use couriers generally for the panels; whereas Royal Mail would be the same cost to NI, unfortunately the couriers class it as highlands and islands, so it would be £66.00 inclusive.
PostPosted: Sat Aug 29, 2015 10:11 pm
I need this panel asap . how do I order it ??
PostPosted: Sat Aug 29, 2015 10:44 pm
Having just checked stock, I find we only have the nearside. I will order fresh stock on Tuesday after the Bank Holiday.
I am conscious, not having ordered any of these for a good while, they may suffer a price rise. The Toledo versions recently launched 'retail' at £72.00 and involve identical manufacturing processes.
PostPosted: Mon Jul 04, 2016 2:43 pm
Just looked at the parts list, can anyone give me some more detail on the item "OS rear wing repair £45.00" in terms of what it looks like, or even better, a picture of the part please?
PostPosted: Tue Jul 05, 2016 6:20 am
Can the Club help with 1500SE coachlines, especially the SE from the rear quarter by any chance or point me in the direction of a known supplier/stockist?
Thanks,
Lee
PostPosted: Tue Jul 05, 2016 6:44 am
TDC West Yorks Area Organiser
The Club does indeed supply these very items.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
2004 Volkswagen Polo Twist (PK54 JYG - a new project car)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Sat Aug 13, 2016 8:04 pm
NS Chassis leg £75.00
OS chassis leg £75.00
NS front footwell £70.00
OS front footwell £70.00
NS headlamp mounting panel £35.00
OS headlamp mounting panel £35.00
NS inner front valance repair £45.00
OS inner front valance repair £45.00
NS front subframe mounting kit £45.00
OS front subframe mounting kit £45.00
Hi
Is the "n/s front subframe mounting kit" the mounts or a kit of panels to repair the mounting area?
Its in the list of body panels so I'm guessing repair panels; are the any pics so I can check it will repair the rusted area on my car.
How far does the "chassis leg" panel extend? My car needs the section from the n/s subframe mount forward to where it joins the inner valance panel, {under the battery section on my Toledo }
PostPosted: Sat Aug 13, 2016 8:38 pm
Some of those prices are out of date.
Pictures and current prices here:
viewtopic.php?f=4&t=31388
The box section you describe is actually part of the inner wing, the chassis leg extends backwards from rear subframe mount and runs under the floor either side of gearbox. The subframe mounting kit offers a repair to part of the box section you describe, but it is a fairly crude kit...
PostPosted: Sat Aug 13, 2016 9:00 pm
Thanks, I saw that page earlier but I couldnt find a pic of the box section repair panel. So you think I'd be better off just fabricating patches to weld into the holes etc in this area?
PostPosted: Sat Aug 13, 2016 11:26 pm
Item H shows the extent of the kit; it is part of each of the four sides of the box, plus the tube ferule that the subframe bolt passes through.
PostPosted: Sun Aug 14, 2016 9:44 am
Of course it is!! Don't know how I missed that, sorry and thank you very much.
PostPosted: Sun Aug 14, 2016 9:46 am
The kit gives you a good starting point, though experience shows that some of the plates need a slight fettle, ie trimming off excess metal, for better fit.
PostPosted: Sat Mar 11, 2017 8:40 am
Hi, will be rejoining today but wonder if the club have the parts to help get my Toledo back on the road. The rear drivers side sill/wing was mishandled by a mechanic and the rear corner of the sill and the section of the wheel arch (the skinny part leading into the sill) was crumpled. Will be looking for a new outer sill but wondered if their was a repair section for the wheel arch?
Thanks John
Proud owner of:
1967 Triumph Herald 12/50
1969 Triumph 1300 FWD
1972 Triumph 1500 FWD
