It is currently Wed Nov 21, 2018 7:52 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Wed Jun 20, 2018 3:17 pm
TDC Staffs Area Organiser
It continues:
Ian Rowley; who are you, what are you paying for, and where should I send it????
I can't match purchases to the amounts sent when there are various purchasers owing the same amount :roll:
I know Ian but sadly don't know his number. I can however get a message to him I'm sure.
PostPosted: Sat Jun 23, 2018 10:33 am
Bidding on the following items will close at 6 pm on Saturday 30 June
All items are used parts and untested unless stated otherwise.
161: Another Sprint/1850 automatic flexi-plate:
Item sold: Final bid £50.00: walker71
166: Sprint oil filler cap:
173: An OE Sprint exhaust silencer box; I don't think this has been used:
174: A RH Toledo radiator grille; unusually, this has all six fixing lugs intact:
PostPosted: Sun Jul 01, 2018 6:43 pm
Bidding on the following items will close at 6.00 pm on Sunday 08 July:
184: A TR7 cylinder head:
185: A Sprint distributor mounting plate:
188: A set of new boxed AutoDelta asbestos free brake shoes for 1500 and 1850 with bonded linings:
189: A new old stock speedometer head for the 1500 TC:
PostPosted: Thu Jul 12, 2018 1:49 pm
Bidding on the following items will close at 6.00 pm on Thursday 19 July:
192: An early 1850 coin tray and gear lever gaiter (small rips in gaiter):
196: A random selection of unused gaskets:
198: A pair of new unused crank seals:
199: Speedo cable; bayonet fitting at speedo head, clamp fixed at gearbox (1850/1500 non overdrive?):
204: Front & Rear ash tray:
205: Washer pump/motor:
210: Gearbox inhibitor switch:
211: Fuel filler pipe to tank connector:
212: New old stock QH water pump for 1500 engines fitted with viscous fan with gasket and tolerance ring:
PostPosted: Thu Jul 19, 2018 11:16 pm
Bidding on the following items will close at 6.00 pm on Sunday 29 July:
217: An offside rear door in saffron from a 1972 car. This, whilst not perfect, is one of the best offside rear doors I've seen available in recent years. Strictly collection only on this; it's currently still in Hampton, but could be transported to Fleet, Wokingham or Stourbridge for collection. If collecting from Hampton, it will be by prior arrangement on a Saturday when I'm planning to be there. I'm putting a reserve of £60 on this due to its rarity and condition.
Item sold, final bid: £60.00: Mahesh
218: A nearside rear door, allegedly from the same 1972 car, but the colour is somewhere between Inca and Mimosa! This door is also in good condition and still has the factory protective plastic sheet on the inside. Strictly collection only on this; it's currently still in Hampton, but could be transported to Fleet, Wokingham or Stourbridge for collection. If collecting from Hampton, it will be by prior arrangement on a Saturday when I'm planning to be there. I'm putting a reasonable reserve of £40 on this due to its condition.
Item sold, final bid: £80.00: Lee16v
219: A boot lid in what appears to be emerald, maybe brooklands green, in good condition with little corrosion, but there is a scratch on the top surface. Strictly collection only on this; it's currently still in Hampton, but could be transported to Fleet, Wokingham or Stourbridge for collection. If collecting from Hampton, it will be by prior arrangement on a Saturday when I'm planning to be there. There is no matt black to the rear panel, but it comes complete with Triumph and Dolomite Sprint badges and a lock (no key):
220: A pair of 1973 dated Sterling Metal alloy wheels (Collection preferred as wheels are on the couriers restricted list, so the package cannot be insured; the wheels are currently in Stourbridge. Postage at buyer's risk):
Item sold, final bid: £40.00: MikeyB
221: A single 1975 dated GKN alloy wheel (Collection preferred as wheels are on the couriers restricted list, so the package cannot be insured; the wheel is currently in Stourbridge. Postage at buyer's risk):
Item sold, final bid: £15.00: MagentaSprint
222: A single 1977 dated GKN alloy wheel (Collection preferred as wheels are on the couriers restricted list, so the package cannot be insured; the wheel is currently in Stourbridge. Postage at buyer's risk):
223: Another bonnet release cable:
224: Another choke cable; no switch:
225: Another speedo cable with bayonet fixing at head, screw fixed at gearbox (1500/1850 with overdrive?)
226: Heater cable:
Item sold: Final bid £5.00: Sprint 95m
227: Late 6 vane water pump cover:
Item sold, final Bid: £5.00: Tony G
228: Another pair of early sidelights with cables and bullet connectors intact; rubber boots slightly perished and the fixing hole for one lens has broken but is supplied so may repair:
Item sold, final bid: £20.00: Nuno Lima
229: Another set of four window winders of varying quality:
230: A pair of good condition OE 'Paulstra' Sprint carburettor mounts; no immediate signs of cracking:
Item sold, final Bid: £20.00: Lee16v
231: Another pair of Sprint engine mounts and brackets; not quite as good as the last pair, but in my opinion, serviceable:
Item sold, final bid: £15.00: SprintChris
232: A HS4 SU carburettor for the non HL 1500 and 1300 partially dismantled (NB needle has been bent):
233: Another (and the last) 1850 clutch operating fork:
PostPosted: Thu Aug 09, 2018 8:59 pm
BIDDING ON THE FOLLOWING ITEMS WILL END AT 7pm ON WEDNESDAY 15 AUGUST:
234: Another battery earth cable:
Item sold, final bid: £15.00: russetauto
235: New old stock 1850 throttle cable NB: BELIEVED FOR SU CARBS ONLY (double nut on threaded sheath at carb end):
236: Boot board to cover inner light panel; not perfect, but reasonable. One screw hole has been torn through, collection only:
Item sold, final bid: £10.00: oldengineer
237: A pair of black front door cards in reasonable condition; no speaker holes, but some edges of vinyl need reaffixing to back boards. Collection preferred:
Item sold, final bid: £30.00: oldengineer
238: New old stock early rear bumper blade. Still has factory cloth fixed to topside, underside is spotless:
Item sold, final bid: £65.00: Alan Crome
239: Smiths oil pressure gauge and capillary pipe:
Item sold, final bid: £15.00: ham204
240: Time clock:
241: Multi-gauge, Triumph 2000 MkII
Item sold, final bid: £10.00: Carledo
242: Multi-gauge, non HL Dolomite
243: New old stock speedometer:
Item sold, final bid: £12.00: Marko
244: Sprint intermediate speedometer showing 95 357 miles:
Item sold, final bid: £10.00: Sprint95m
245: New old stock early 'Dolomite' (ie 1850) speedometer, boxed:
Item sold, final bid: £40.00: James 467
246: Heater blower:
Item sold, final bid: £6.00: Marko
247: Front springs, no idea of specification, but measure 275 mm free length (standard Dolomite free length is 344mm):
Item sold, final bid: £5.00: cliftyhanger
248: Another plastic expansion tank:
249: Brass expansion tank:
Item sold, final bid: £10.00: Toledo Man
250: Fan and viscous coupling. NB: Diameter of fan is 13", standard Sprint is 14", so could be Spitfire/1500?:
251: 13" Astrali steering wheel, fits Dolomite column:
252: Pair of rear Spax adjustable shock absorbers fitted to springs:
Item sold, final bid: £50.00: Yorkshire_spam
253: Automatic brake pedal rubber with very little wear:
Item sold, final bid: £5.00: Toledo Man
254: Another pair of rear Spax adjustable shock absorbers fitted to springs but also with adjustable seat height also:
Item sold, final bid: £35.00: cliftyhanger
255: Offside rear early grab handle:
PostPosted: Tue Aug 21, 2018 6:59 pm
I've edited all but the last two listings, removing the sold items to highlight the as yet unsold items. There'll be some more listings soon...
PostPosted: Sat Sep 15, 2018 9:02 pm
Having seen the one in Essex go for good money on eBay, I thought I'd sell Jon's by the same method:
https://www.ebay.co.uk/itm/New-Old-Stoc ... Swcxhbm3yn
If anyone wishes to make a meaningful offer on it, I'll give such offer consideration whilst there are no bids on it.
PostPosted: Sat Sep 29, 2018 9:18 pm
Bidding on these items will end at 6 pm on Sunday 07 October.
256. Sprint rocker and cam bearing cap assembly
257. New old stock long arm fuel pump
258. Clutch slave cylinder clamp for 1500
259. New old stock rear crankshaft oil seal for Sprint, 1850 and TR7:
260. A pair of reasonable condition sun visors (black and white style):
Item Sold, final bid: £10: covcourier
261. A pair of early internal trim panels to the A-post/footwell area, along with a single nearside version of the nearside equivalent to later cars. The hardboard from the later one may render its inner hardboard panel to repair the offside early one which is compromised (and photographed twice from both sides). All three are listed as a single lot.
Item Sold, final bid: £10.00: ham204
262. An EARLY sprint cylinder head and rocker cover; the rockers and bearing caps are separate, but all were stored in a box together so I assume they belong to each other. No cam:
Item Sold, final bid: £65.00: NunoLima
263. An incomplete set of Vandervell 10 thou main bearings for Sprint, 1850 and TR7. There are only 9 in the packet. I had been hoping to discover the 10th, but the individual single unused shell I did find was AE Glacier! This is included if you feel like chancing it:
Item Sold, final bid: £5.00: tony g
264. A front door corner filler piece in good condition:
Item Sold, final bid: £10.00: oldengineer
265. An unused front wheel bearing kit:
Item Sold, final bid: £5.00: ham204
266. A pair of late seat belts complete with stalks:
Item Sold, final bid: £12.00: Sprint chris
267. A new old stock boxed rear brake hose GBH166:
268. A pair of late bumper under riders in reasonable condition:
269. A pair of Sprint engine mounts complete with engine brackets; both seem serviceable, but one is better than the other.
Item Sold, final bid: £15.00: magentasprint
270. A Sprint clutch cross shaft:
271. A set of new old stock Moprod brake pads:
272. A remote clutch fluid reservoir, whilst dirty, it is sound. No cap
274. A pair of new old stock bagged and sealed front hub oil seals for Spitfire Vitesse and GT6 GHS146
275. Black furflex. 5 lengths:
Item Sold, final bid: £20.00: Sprint95m
276. 1850 overdrive gearbox rear bracket. Mount not included.
277. Sprint clutch slave cylinder bracket:
PostPosted: Sat Oct 06, 2018 7:06 pm
Hmmmm now is this auction for the last lot of advertised items really running for another 12 months Alun or did you do a little typo :wink: :wink: :lol:
PostPosted: Sun Oct 07, 2018 10:54 am
You have me there!
PostPosted: Sun Nov 04, 2018 6:55 pm
Bidding on the following items will end at 12 noon on Saturday 10 November. I will be on the Club stand at the NEC on Sunday 11 November if winning bidders want to collect by prior arrangement
278: A set of black door cards: These are not the best I've ever seen, but by far not the worst! The front passenger has suffered from the damp at some time and is slightly distorted; I'm confident it is recoverable. The driver's rear has a corner of the hardboard creased, but it is intact. Several areas of vinyl and the fluff at the bottom need re-adhering to the hardboard on the rear faces. To be sold as a set:
Item sold final bid: £60.00: sprintchris
279: An original old Payen branded 'conversion' gasket set for the 1850 reference EK270 (will fit Sprint too):
Item sold final bid: £10.00: yorkshire_spam
280: Two OE sump gaskets for the 1500 (AJM517) These are good thick gaskets with asbestos. Sold as a pair as postage will be disproportionate for just the one!
Item sold final bid: £5.00: marko
281: A 'new' Payen branded 'conversion' gasket set EG091 for the 1500:
282: A glovebox handbook for the 1850:
283: A 'Supra' branded head gasket set for the 1850:
284: An unused Baines branded 'screen rubber complete with brightwork insert:
Item sold final bid: £25.00: sprintchris
285: An original old Payen branded head gasket set reference CK270 for the 1850:
Item sold final bid: £15.00: yorkshire_spam
286: An 'Ultraparts' branded sump gasket for the 1850 or Sprint; good thickness:
Item sold final bid: £10.00: GTS290N
287: An unbranded head gasket for the TR7:
Item sold final bid: £5.00: dursley92
PostPosted: Fri Nov 09, 2018 10:28 pm
I'm now heading to Cardiff tomorrow slightly earlier than planned so I can be there in time to watch England v All Blacks, which is being screened before the big match, so any last minute bids won't be seen by me, nor the final bids updated, until my return late evening.
