It is currently Fri Nov 24, 2017 8:18 pm
Post new topic  Reply to topic  [ 517 posts ]  Go to page Previous 131 32 33 34 35
PostPosted: Tue Nov 14, 2017 12:42 pm
TDC Spares Officer
It has been ages since I did an update and quite a lot has been going on.
RUK has been running pretty much every day doing the school run, add into that two trips up and down the M40 and it has been a busy car!
The trackerjack brakes are now fitted and in the auto they definately work better. The biggest thing I have noticed is that it now takes less effort to stop the car when running on choke in the traffic.
The other thing is that it will cruise all day at an indicated 80mph now and after running up and down the M40 a couple of times the engine is running really sweet.
I have removed the MGF seats as I do prefer the look of the originals and they are actually much more comfortable.
If you have seen the car at the NEC and Stoneleigh recently you will know that I have found and fitted some door pockets and speaker pods, these actually reinforce the bottom of the door cards, mine were quite wavy and coming away from the door and fit perfectly, with some flocking they will look like they were meant for the car.
You also have the benefit of not only having a nice door pocket but somewhere to mount some 13cm speakers. They don't interfere at all with your feet placement, I have been driving around with them in for a few weeks now and I dont even knock them when getting in and out for the car.
RUK also made an appearance at both the NEC and Stoneleigh on the club stands doing a great job of transporting the regalia around as well.
In terms of its health RUK has developed a few oil leaks. The rear crankshaft oil seal is leaking profusely, the front oil seal leaks, and there is a bad oil leak from the water pump, uses no water at all though. After a long run of about 120 miles I am having to put in quite a bit of oil.
The rear axle pinion seal also has a bad oil leak and the rear wheel bearings need replacing and there is quite a bit pf play in there steering.
I also need to go over the auto box and drop the sump to replace the pump strainer and check the brake band tensions as on the way back from the NEC there was some difficulty changing from 2nd to 3rd.
So I may as well drop the subframe and pull the engine and box out plus the rear axle, repair the oil leaks and replace the bushes and ball joints at the same time.
Not wanting to start and argument but I am not putting in polybushes, I drive this car every day and do long distances as well and polys will ruin it.
PostPosted: Tue Nov 14, 2017 1:00 pm
TDC Spares Officer
I had a thought, NWLs engine needs building. I didn't want to build it and leave it laying around for ages once built, also once the car is back on the road it wont be doing a lot of mileage so I could build the engine up and fit it to RUK with the gearbox and back axle to run them all in whilst I sort all the oil leaks and gearbox out on the original engine.
Now before you go saying oh my god, thats sacrelidge blah blah! You probably aren't familiar with NWL so read my thread here
You will then realise how much NWL means to me and that this would NOT be a permanent swap.
But it would give me the opportunity to iron any bugs out on NWLs engine, I have the TJ kit so wouldn't need the brake valve on the back and of course the mod would be declared to my insurers.
As far as I can see the only thing I would need to do is to get some bigger wheelnuts as my Sprint is a later car using the larger studs, I have everything else including an exhaust.
PostPosted: Fri Nov 17, 2017 4:25 pm
Oh my dog! Sacrilege blah bl...
Oh wait, hang on.
Sound downright sensible to me.
PostPosted: Fri Nov 17, 2017 4:34 pm
It sounds like RUK is your new mistress :twisted:
PostPosted: Fri Nov 17, 2017 8:24 pm
Want to part with the horrible MGF seats and homemade runners James? I could do with seats that tilt in the Carledo!
2 door '73 Toledo with Vauxhall Carlton engine OWF 797M (The Carledo)
Vermillion (and Rust) Sprint Auto EGP 247T (The Dolomega)
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
Spectrum Auto Services, Servicing, Repairs, MOT prep. Apprentice served Triumph Specialist for 40 years and home of Maverick Triumph.PM for more info or quotes.
PostPosted: Fri Nov 17, 2017 8:36 pm
It's not a bad theory, but will involve swapping a load of other bits to do the manual conversion, subframe, prop, tunnel, pedals, clutch hydraulics etc. If swapping in the Sprint axle is planned too, why not swap in the Sprint front hubs and use Sprint wheels and nuts? Or, if you like I could lend you some 7/16 UNF steel tapered nuts.
PostPosted: Sat Nov 18, 2017 10:42 am
TDC Spares Officer
Agree with the Sprint swap so I have another plan which involves DTR (as its already a manual) as RUK may be going to a new home.
Users browsing this forum: 10yearsafter and 1 guest
cron
