It is currently Tue Apr 16, 2024 12:52 pm
 Post subject: Restoration
PostPosted: Tue Sep 22, 2009 11:21 pm
:bluewave: This years plan to get my striped shell restored hasnt happen yet due to other home improvements :oops: so iam going to take off the panels that need replaceing before its dipped at spl.What is the best way and where abouts on the front wings and front panel do i cut.Any pics of this being done will help.
 Post subject: Re: Restoration
PostPosted: Wed Sep 23, 2009 7:37 pm
TDC Staffs Area Organiser
If it's any help it's probbaly best to repair and then dip or else you'll have to take it back again.
I think maybe you need to be clearer which bits you need to remove and is it a case of replace or can they be repaired. Generally it's a case of drilling out spot welds and undoing the joining seams. Also don;t forget that what looks bad now will look a whole lot worse when you start cutting out as you'll discover more and more rot.
PostPosted: Wed Sep 23, 2009 9:08 pm
As that Churchill dog would say...........Oh Yes !
PostPosted: Thu Sep 24, 2009 1:28 am
The sills /front wings/front panel rear panel /inner & outer wheel arches are going to be replaced. :woohoo:
PostPosted: Sat Sep 26, 2009 6:26 pm
You should find some of the answers you need here. viewtopic.php?f=19&t=2400
also if you look in some of the other project threads you will probably find alot of the other answers aswell, any more specific questions and just ask.
Neil
PostPosted: Sun Sep 27, 2009 10:53 am
:bluewave: very usefull info.Thanks
Users browsing this forum: No registered users and 18 guests
