Hi thought i would check in and let you all know the latest on the resto of JYP, i have now sourced all the panels ready to be fitted these include inner, outer and strenghteners for both sides of the cills and a pair of chassis legs (starting to wonder what part of the car will actually be original) also received the second run of powder coating back which once again was very cheap but excellent quality, started to de-grease the axle tonight which whilst in storage has leaked all over the garage floor and caused everthing in its path to get covered
.I started by taking off the rear cover to inspect inside which all seems ok but i am not sure what parts are worth changing while i have it off the car and why it dropped all the oil out? the underside of the axle was wet when it was on the car so it already had a small leak mainly around the flange? that the prop attatches too
