Froggy Dolly http://forum.triumphdolomite.co.uk/viewtopic.php?t=18642 |
Page 5 of 6 |
Author: | Dolly-Dimple [ Tue Sep 22, 2015 10:08 pm ] |
Post subject: | Re: Froggy Dolly |
Hello dololo, hope you are well? Do you still own your lovely 1850? Kind Regards Russell. |
Author: | dololo [ Sat Sep 26, 2015 9:18 am ] |
Hi all Since Jeroen sent me a gearbox cover , it is now a pleasure to drive my dolo , approx 1000 miles per year tomorrow we are going for à 100 miles trip in the north of France the only problem is that a right front breaks begin to block there is some brake mud on the wheel , i will check today, but the seals and piston are new , so i guess what to do .... |
Author: | Dolly-Dimple [ Sat Sep 26, 2015 5:38 pm ] |
Excellent!!! Glad you are enjoying the car |
Author: | Edin Dundee [ Sat Sep 26, 2015 5:50 pm ] |
Quote: Hi all
Hi, long time no hear.Since Jeroen sent me a gearbox cover , it is now a pleasure to drive my dolo , approx 1000 miles per year tomorrow we are going for à 100 miles trip in the north of France the only problem is that the right front brake begins to lock there is some brake dust on the wheel , i will check today, but the seals and piston are new , so i guess what to do .... Maybe you have a dodgy brake hose to that wheel, or maybe just a removal of the pads and vigorous clean with an old chisel on the slides and some copper grease might do the trick. I think xvivalve does refurbished calipers at an excellent price, not sure what it would cost to ship to France. |
Author: | dololo [ Wed Aug 29, 2018 8:44 pm ] |
hello, a long time since i came on the forum ...disappointed to learn for Jon . I have some issues with front suspensions . What would you recommend for the rubber bushes , to obtain quality parts , and for front schock absorbers , considering i will maybe upgrade the car to sprint version. regards Laurent |
Author: | Galileo [ Wed Aug 29, 2018 10:22 pm ] |
Look no further than Chris Witor's Superflex bushes: https://www.superflex.co.uk/categories.php?cat=157 |
Author: | Toledo Man [ Thu Aug 30, 2018 6:31 am ] |
Chris Witor offers a discount for TDC members on the Superflex bushes. |
Author: | dololo [ Wed Sep 05, 2018 8:55 pm ] |
I am now guessing about buying a donnor car with papers, in order to make a sprint . But the engine is blocked. Where can i find quality parts to rebuild an engine ? Is a sprint head as difficult as a 1850 to put off ? |
Author: | xvivalve [ Wed Sep 05, 2018 9:20 pm ] |
You need to shop around for quality parts, sometimes they crop up on ebay and other market places, sometimes you need to place 'wanted' adverts.Where can i find quality parts to rebuild an engine ? Is a sprint head as difficult as a 1850 to put off ? Sprint heads are usually easier as the studs are protected beneath the rocker cover. |
Author: | dololo [ Tue Oct 16, 2018 9:37 pm ] |
good evening looks like problems are coming : my expansion bottle stays Under pressure even when the car is cold and the engine shut . no loss of coolant , no overheat . A small leak in the zone under the waterpump Have some ideas ? Laurent |
Author: | tony g [ Tue Oct 23, 2018 2:17 pm ] |
Take the pipe off the bottle and make sure it is clear. Check the connecting "tube" from the thermostat housing is clear too. Tony |
Author: | Carledo [ Tue Oct 23, 2018 8:49 pm ] |
You are worried because you have a cooling system that actually HOLDS pressure? This is not a problem, it's a minor miracle and I envy you! Steve |
Author: | dololo [ Tue Oct 23, 2018 8:55 pm ] |
no, i am worrying because i find the level much higher than i left it before my last tour . And much higher than the maxi level indicated on the bottle . i've found the thermostat housing empty when the bottle became full |
Author: | dololo [ Thu Oct 25, 2018 3:04 pm ] |
Sorry , can't see your picture is it a picture of the recommended modification ? thanks for your help |
Page 5 of 6 | All times are UTC |
