It is currently Mon May 21, 2018 8:57 pm
Post new topic  Reply to topic  [ 176 posts ]  Go to page Previous 16 7 8 9 1012 Next
PostPosted: Mon Jun 22, 2015 12:06 pm
You will get varying opinions on that Shaun. I say they should be fitted from the engine side (as per the manual) but others will disagree. :wink:
2007 Porsche Boxster S
Grammar:
Schedule: Pronounced "Shedule" not "Scedule"!
PostPosted: Mon Jun 22, 2015 2:05 pm
I was told to fit mine from the inside so it can't fall out, which made sense
PostPosted: Mon Jun 22, 2015 2:53 pm
Same. It hasn't disintegrated, caught fire or landed me in the hedge so I assume it's no bad thing ;)
1978 Triumph Dolomite MX-5 Build (Project) viewtopic.php?f=19&t=29239
1959 Morris Oxford IV Traveller in Red/Cream (Daily)
PostPosted: Mon Jun 22, 2015 4:17 pm
....the plastic bush sat in the bulkhead plate has its biggest diameter on the interior of the bulkhead rather than the engine side....is this correct?
Yes. :)
White Dolomite 1850 HWM 572P
Bill.
PostPosted: Mon Jun 22, 2015 5:16 pm
Yes. :)
NO!
Grammar:
PostPosted: Mon Jun 22, 2015 5:24 pm
We're talking about the same thing? The bush at the bottom of the steering column?
The big bit sits inside the car, the small but in the engine bay.
http://www.chriswitor.com/proddetail.php?prod=153868P
Bill.
PostPosted: Mon Jun 22, 2015 7:22 pm
I vote yes! big collar to top.
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Mon Jun 22, 2015 7:30 pm
Deffo!
I put mine in, big bit in, as it is virtually the same size as the washer at the bottom of the steering column, thereby giving a larger bearing area than the small end...I can see though that this might offer a little too much friction perhaps?
*stoppress*
Just swapped it round and actually it does look more like it is engine side in as opposed to the above! Any movement rearwards from the steering UJ and it would pop the bush out into the footwell......
Still searching for Sprint UUW 410M....If you know it or see it, I want it back! Now known to be in the Llandudno area....
Please get in touch!
PostPosted: Tue Jun 23, 2015 8:59 am
In several cases back in the day when I had cars where this hadnt been done since they left the factory the bush was always
fitted from inside the car as in the pic above.
Its also entirely probable that the workshop manual says to fit it round the other way. If the u/j can moves backwards enough to
push it out I think you have other more important issues to deal with.....:-)
PostPosted: Tue Jun 23, 2015 10:01 am
I'm pretty sure that when I took the plate and bush off originally, the bush was inside, but actually having had it in both orientations, I don't think it matters?
PostPosted: Tue Jun 23, 2015 10:16 am
It should be fitted like Mart says - largest part in engine bay. That way the lip of the bush stops it moving backwards into the car, and the UJ stops it moving outwards. If you fit it the other way round the slight movement of the subframe on the rubber mounts will work the bush off its lip and inside the car. Thats why its designed the way it is.
Its also the way shown in all the manuals, and the way my 10,000 mile from new Dolomite had its original bush fitted.
Matt.
PostPosted: Wed Jun 24, 2015 4:33 pm
Thanks again for that info Jonners, I'll check the u/j. Chassis repair done.
David
PostPosted: Wed Jun 24, 2015 6:31 pm
Matt.
Hmmm, Is this now the definitive answer? Sounds logical.....
Bill.
PostPosted: Thu Jun 25, 2015 8:39 pm
Well I'm not taking mine out to turn it over!
 Post subject: Hmmm.......
PostPosted: Fri Jun 26, 2015 9:48 am
Matt.
At the bottom of the steering column shaft is a washer. This will stop the bush from sliding up the shaft (and into the car).
The original bushes break up over time.
There should not be any movement of the subframe. Worn bushes or (in more drastic cases) failed cup washers will allow this.
Any likely movement is of the steering rack relative to the subframe (and therefore the car). The OE s/rack bushes have a short lifespan. This
is detrimental to the lower steering coupling.
The Superflex bush can be fitted either way round.
Users browsing this forum: yorkshire_spam and 1 guest
cron
