It is currently Fri Jul 20, 2018 3:00 am
Post new topic  Reply to topic  [ 68 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Fri Apr 06, 2018 4:39 pm
Good to see you back.
PostPosted: Sat Apr 07, 2018 9:10 am
nice work :D
Dolomite 1300,1980`V`reg in british racing brown(russet),3.63 diff with 21t speedo pinion,95%poly`d,HL clocks,standard wheels with SE covers wrapt in 175 70 13,mot`d 19-09-2014,been off the since 1990,(july2017) stainless steel exhaust 3-piece.
Dolomite 1300,1977(tax free 1-1-1977),`R`reg in carmine red,bog standard including rust :shock: last time on road 6-2005
PostPosted: Sat Apr 07, 2018 4:51 pm
The finished boot and battery install
1971 2 door Toledo aka Chuckie (porsche orange)
PostPosted: Sat Apr 07, 2018 7:45 pm
Did you buy the battery tray,or make it,if you made it now did you get the holes
in it,the shape bunnies i mean
PostPosted: Sat Apr 07, 2018 8:13 pm
I bought it, bolted it in and hey presto. Beats the old setup where the previous owner just threw it in the spare wheel well
PostPosted: Sat Apr 07, 2018 9:41 pm
Use two sizes of tube offcuts, smaller first place under the sheet metal, hammer around to form a crease, cold chisel around circle to cut out metal smooth with a file if needed, or use a hole saw to cut the initial hole. Swap to slightly a larger diameter pipe offcut under the sheet and use a bossing mallet to finish off the hole.
Edit: Found a video!
PostPosted: Sun Apr 08, 2018 7:06 am
I wish I had the time and patience to do that. It would be very satisfying. It’s taken me long enough to do just the boot so it’ll be shop bought items for me
PostPosted: Sun Apr 08, 2018 12:34 pm
Thanks for posting link
cron
