Hello all, thought it was time to put this on forum.
Saved from local scrapyard in May, was listed on Ebay a few times but had no takers, I was'nt looking for dolly at time but it was going to be crushed so could'nt let that happen.
Its a very early Dolly reg on 13th Jan 72 and is in remarkable condition considering it does'nt look to have been restored much before, came with two original service books stamped to 60k.
Has had 1850 engine removed and Range Rover v8 put in(by previous owner), not plumbed in just resting on subframe no gearbox, other running gear seems to have been replaced by sprint parts and the interior.
Will need some welding, obvious issues are both sills on leading edge, offside front subframe mount and rear offside arch is a bit nasty .
Underside is very good only surface rust but is unfortunateley dented due to being on rack in scrapyard.
Since getting it I have just given it a good clean, replaced tyres and polished alloys, dont have anywhere to store it so it is parked behind my shop outside, have to keep it clean so it doesnt look abandoned.
Whats next ? not sure I have three other classic cars in use so a fourth just seems silly.
