1850hl russet brown http://forum.triumphdolomite.co.uk/viewtopic.php?t=26411 |
Page 1 of 2 |
Author: | going_downhill [ Thu Jan 02, 2014 8:53 pm ] |
Post subject: | 1850hl russet brown |
Far from a resto, but progress either way and almost ready for the MOT! I've managed to resolve a fair few niggles that needed addressing with a little help from the forum. An oe antenna was fitted to replace the modern aftermarket one, thanks to Mike on here for supplying it. After a worrying drive home from Dublin to Nottingham (worrying but trouble free) without any temp or fuel gauge it was thankfully an easy fix by changing the voltage stabiliser. The drive was made even more amusing by the fact the satnav on the mrs's phone was set to avoid motorways, so we went down a fair few country roads in the middle of the night with no full beam, again this was an simple fix with some forum knowledge and a new stalk switch! i really loved the old pioneer 8 track player when i owned this car the first time around, 5 years a go. After wiring it up it seemed it had seen better days and i wasn't getting a pleasing sound from it. Rather than sling it i sent it off to agenta audio for a service where Colin worked some magic and replaced the internal amplifiers to bring the sound back to how it was intended to be. Id recommend him to anyone with a ropey vintage radio! still left to complete is a replacement drivers side footwell, I've got the panel bit just need someone with some welding expertise. I think it may make its way to a body shop in the next couple of weeks. Oh and i still need to source the 1850 front pipe bracket as mines sheared! I think club stock has ceased and no joy with rimmers. |
Author: | Toledo Man [ Thu Jan 02, 2014 8:56 pm ] |
Post subject: | Re: 1850hl russet brown |
Don't forget to put some photos up. |
Author: | going_downhill [ Thu Jan 02, 2014 9:26 pm ] |
Author: | grifterkid [ Tue Mar 18, 2014 11:13 am ] |
That is a corkey of a Dolly there... I am infinitely jealous of your 8-track player! |
Author: | Pippin [ Tue Mar 18, 2014 8:46 pm ] |
The circular black plastic part between the chrome window winder and the door card on your driver's door doesn't look quite right to me. Is it on backwards? Then again, it might just be my eyesight! That aside, it looks a lovely car. Jer |
Author: | going_downhill [ Tue Mar 18, 2014 10:39 pm ] |
Quote: The circular black plastic part between the chrome window winder and the door card on your driver's door doesn't look quite right to me. Is it on backwards? Then again, it might just be my eyesight! That aside, it looks a lovely car.
i haven't noticed a problem but will compare it to the other side. Thanks for the observation. Jer i don't suppose anyone has any spare footwell bungs do they? |
Author: | Jon Tilson [ Wed Mar 19, 2014 10:24 am ] |
Moss have the bugs so I suspect others do as well. Jonners |
Author: | Flyfisherman [ Tue Jan 30, 2018 4:08 pm ] |
There fat toyo tyres - what size are they please. Paul |
Author: | going_downhill [ Tue Jan 30, 2018 4:48 pm ] |
They are 185 60 13 but i'm told the R888R comes up slightly wider than a regular 185 60. They seem bang on for sprint rims either way. Speedo seems to be spot on to even though they come up slighty smaller in overall diameter than the original sprint tyre size.
Paul |
Author: | LJColeman [ Thu Feb 08, 2018 5:46 pm ] |
Wow this looks awesome! exactly how i want my 1500HL to Look!! How do you find it now with the suspension & bushes etc? |
Author: | going_downhill [ Mon Feb 12, 2018 2:33 pm ] |
Its plenty stiffer than it was and does corner really well. A little crashy over bumps but not as bad as i was expecting. Its still very drivable and i've not lost any teeth yet.How do you find it now with the suspension & bushes etc? I am going to have to raise the front a little. As clearance between the ground and the front subframe, plus some exhaust mounts is shocking. Cant avoid speed humps forever. |
Author: | dollyman [ Mon Feb 12, 2018 10:55 pm ] |
Looking good |
Page 1 of 2 | All times are UTC+01:00 |
