Russet brown Dolomite 1300 OVX499V 53000miles http://forum.triumphdolomite.co.uk/viewtopic.php?t=27611 |
Page 1 of 20 |
Author: | tamtrucks [ Sun Jul 13, 2014 11:52 am ] |
Post subject: | Russet brown Dolomite 1300 OVX499V 53000miles |
hi all bought this last year of rob grainger after selling my 2000mk1 estate triumph dolomite 1300,V-reg,first reg 11-7-1980,53000 ish miles with all past history,mot`s in order i got it and it needed alot of work,but all time consuming,supplied with sills-driver and pass ive replaced--- clutch all bushes(polyed) except the front wishbone rubber dust covers Front subframe stript,cleaned,rust-treated,painted Rear axle off stript and cleaned,rust treated and painted Rear brakes,new cylinder,cleaned adjusters,new shoes,skimmed drums Interior out and cleaned new/second hand brakes to go on front must say big thanks to mikew the original brake were shot,,all 4 barrels pitted,seals gone body work is very clean for its age(34) Engine needed a fuel pump,bit of go-go juice and she fired up,,no rattles or funny noises,,runs sweet,very good oil pressure replaced the points,rotor arm,sparks,fuel pump,air filter,oil filter,oil,new battery got new front screen to go in,as the one thats in is seperating and making fog patches,got rear as spare driver sill replaced,and the underside to be cleaned,rust treated and painted,,body getting done now thanks nic |
Author: | Pippin [ Sun Jul 13, 2014 5:45 pm ] |
Post subject: | Re: Russet brown Dolomite 1300 OVX499V 53000miles |
Hi Nic, Looking forward to the photos. Jer |
Author: | Howard81 [ Sun Jul 13, 2014 10:18 pm ] |
Likewise, sounds like you are well on your way with this one |
Author: | tamtrucks [ Tue Jul 15, 2014 9:19 pm ] |
here are a few pictures from when i got it til now http://s1382.photobucket.com/user/dolom ... %20OVX499V 602 pictures |
Author: | Edin Dundee [ Tue Jul 15, 2014 11:00 pm ] |
That was a lot of photo's! And a lot of work. |
Author: | tinweevil [ Sun Jul 20, 2014 10:20 am ] |
Nice work at that. Top stuff. |
Author: | tamtrucks [ Sun Jul 20, 2014 5:49 pm ] |
thanks all for the comments |
Author: | triumphtoledo [ Thu Jul 24, 2014 9:25 am ] |
Wow! So nice to see a 1300 get some love - my first one was also in Russet (given to me in 1991) but was too rotten to do save. One day, I'll get one but, with a Dolly 1500 and a Toledo to restore first, it will be a while... The geek in me was interested in your car's engine number, ending in HEY - most ended in HE (or HEA for automatics). I found a brown 1300 in a breaker's yard, also in brown but on a T reg, that had a chassis number that ended in 'DLY'. According to the parts book, the Y on the chassis plate signifies a batch of cars that were supplied to the British School of Motoring and had some little quirks, such as the bigger diameter 1500cc clutch, to cope with learners. R |
Author: | tamtrucks [ Sun Aug 03, 2014 5:05 pm ] |
another 80 pictures has been added today now that all welding has been done painted sill bottom pass-side,ready to fit petrol pipe tube/s,driver side left to do,just seam sealed it,orginal dash back in,front put back on,headlights,grill,number plate,just need to fit indi/side lights |
Author: | tamtrucks [ Wed Aug 13, 2014 7:49 pm ] |
added more pictures today,,,flat dash hl/sprint clocked,rear number plate light bracket that fit behind the number plate so i could de-bumper it,just need chrome finish to follow(sprinty) |
Author: | tamtrucks [ Fri Aug 22, 2014 3:48 pm ] |
bumpers are going back on,,,dont look right with out sprint rear trim got 2 perelli p3000 fitted to front oil pressure gauge mount and plumped in,saved from old triumph 2000 mk1 estate i had changed carb from 21.5 to 22.5 which is the correct one for the year tuned up,,,colortune and timing light,,sounding sweet next is the mot,next month`ish |
Author: | tamtrucks [ Sat Sep 06, 2014 4:23 pm ] |
removing front windscreen any pointers/info on how to remove the screen? rubber still good,just screen peeling apart got screen to go in but ive never done one |
Author: | Edin Dundee [ Sat Sep 06, 2014 4:34 pm ] |
I've only done one, just pushed it out from the inside, rubber and all, pushing the rubber and the screen at the same time, from the top. I put lots of bubble-wrap on the bonnet just in case it came out quickly and damaged the paint, but it just sat there and I could lift it away from the outside. |
Author: | Tony Burd [ Sat Sep 06, 2014 4:40 pm ] |
As above, but take the filler trim out of the rubber seal first. |
Author: | tamtrucks [ Sat Sep 06, 2014 4:45 pm ] |
thanks for the info,yes ofcoarse remove the insert trim first |
Page 1 of 20 | All times are UTC+01:00 |
