It is currently Mon May 21, 2018 8:53 pm
Post new topic  Reply to topic  [ 221 posts ]  Go to page Previous 111 12 13 14 15
PostPosted: Fri Oct 06, 2017 11:53 am
no baffles inside as my metal tank has none either,so tried to keep it the same
did original dolly tanks come with baffles? ive got 77 and 80 both have no baffles
not sure on volume of tank but cant be far off 57L/12.5gallons,il be happy with 50L tank,saves on carrying excess fuel
Dolomite 1300,1980`V`reg in british racing brown(russet),3.63 diff with 21t speedo pinion,95%poly`d,HL clocks,standard wheels with SE covers wrapt in 175 70 13,mot`d 19-09-2014,been off the since 1990,(july2017) stainless steel exhaust 3-piece.
Dolomite 1300,1977(tax free 1-1-1977),`R`reg in carmine red,bog standard including rust :shock: last time on road 6-2005
PostPosted: Fri Oct 06, 2017 2:00 pm
just measured the tank,and calculated on website convertor that the tank is 44.6L,so lost 12L,that includes the mod to be done
PostPosted: Fri Oct 06, 2017 2:55 pm
TDC Staffs Area Organiser
There aren't any baffles as such but there is a small container within the tank where the sender sits which acts as a baffle for the sender unit.
It does look quite nice though I think if I were fitting an alternative tank I'd look to fit a foam filled jobbie for safety, the tank is in just about the worst position in the event of a rear bump.
1961 Chevrolet Corvair Greenbrier
2015 BMW 118d Sport
PostPosted: Fri Oct 06, 2017 3:28 pm
in my tank there no container at all,tank from the 77 dolly i got
PostPosted: Fri Oct 06, 2017 7:12 pm
The reason you would have small container inside the tank by the pick up,is when you get low on fuel,it will slosh about and could loose the fuel around the pick up pipe,and the car could cut out as no fuel would be pumped
PostPosted: Sat Oct 07, 2017 2:13 pm
AS OE the tank capacity was 12.5 gallons....nice long range at 40 mpg.
There should be baffles around the tank sender flat arm, which makes fitting it a bit of an art, but worthwhile to stop it
flopping up and down too quick as the level drops and the fuel sloshes around.
PostPosted: Sat Oct 07, 2017 2:33 pm
thanks for comment,,nice one
drop tank off for mods last night,just phoned now-explained,he`s on it
PostPosted: Sun Oct 08, 2017 2:59 pm
[/quot
what's it made from alli or stainless ? It looks nice
PostPosted: Mon Oct 09, 2017 10:04 am
alloy 3mm
PostPosted: Sat Nov 04, 2017 9:03 am
got the fuel tank back. needs fettling to fit
PostPosted: Thu Dec 28, 2017 5:24 pm
yesterday,bought a new in box fuel sender unit(2pin)now got a spare,not done nothing to alloy tank as its needs work,may have to buy tig welder :D thinking of selling the red dolly on :( but browny is still good,rear window demister works 8) now done 63600`ish since i got it
cron
