I have also cleaned up the hubs. The outside got a light blast followed by a through degreasing. I let some grease inside to catch the blasting media so we don't get wrecked bearings!
They've had a coat of red oxide with the anti roll bars and I'll give them a few coats of satin black tomorrow.
I'm not powder coating the hubs because I need to retain the machined surfaces, especially where the bolts go through to the discs and where the disc mates to the hub body, pc tends to get everywhere unless you mask up really well which looked like it could be a pain with these so I decided that it's easier to sand off paint than powder coat!
Before and after
Red oxide
Onto the subject of bolts, I'm sure that there's someone her that can shed some light on this for me. The obsessive compulsive side of me loves shiny bolts on a restored car! So I have run all of the load-bearing bolts and suspension washers for the suspension that I cant replace through the blaster at a low pressure to remove any rust and to generally clean them up. Now I'm not sure about what to do with them, I was going to have them plated but have been told that load bearing bolts can fail after the plating process, I'm not sure how true this is and a quick Google search hasn't found much about it. Alternatively I could just paint them in a chrome paint, that way I know we're safe either way I think they need some sort of protection, any thoughts?
Anyway, the front and rear suspension's coming together nicely, getting close to being able to reassemble soon.
