It is currently Sun Nov 18, 2018 9:49 am
Post new topic  Reply to topic  [ 602 posts ]  Go to page Previous 136 37 38 39 40 41 Next
PostPosted: Sun May 22, 2016 10:02 pm
Hablas Espanol también! Soy medio Espanol, embarrassingly can't speak it fluently though.
Think I've got confused here, I've assumed when reading on the forum that the 'eyebrow' is the overhang/lip at the top of the lights, but I've a feeling looking at your pictures that I'm labouring under a misapprehension!
PostPosted: Sun May 22, 2016 11:05 pm
The eyebrow is a reinforcing panel that fits under/inside the top panel and the front edge of the wing - the one towards the top of these photos that has a semi-circular cut-out in its edge:
In this photo the eyebrow still has the rusty remains of where it curves down the inside of the front of the wing ...
... whereas James has neatly removed that part in this photo:
PostPosted: Mon May 23, 2016 7:49 am
TDC Spares Officer
Thats it, I wanted to use the club grp ones and just tigerseal them in but because I have to weld so close I run the risk of them being damaged.
Regardless of them being GRP or original to get the eyebrows in with the panel in place you have to carefully bend the inner lip of the front valance down. It looks scary but should go back as good as new with a bit of hammer and dolly work.
In an ideal world you would remove the wings to do this but I dont want to disturb the seams or visible spot welds.
I'll get some photos up and you'll see what I mean.
PostPosted: Mon May 23, 2016 9:37 am
Ho about a Rimmers eyebrow cut to match the bit of yours that's rusted and join it at the top to your old one?
I agree f/g will last better in this rust trap area but like you say how are you going to weld so close to it?
Thanks for the clarification P....I was a bit confused about what was going on here too...
PostPosted: Mon May 23, 2016 9:46 am
TDC Spares Officer
Way ahead of you Jonners! :wink:
I want to see how they fabricate them especially the corners which are a complicated shape, hopefully I can just copy them. Failing that I'll just cut off the ends and use them if they fit ok.
Yeah, sorry I wasnt being very clear.
PostPosted: Mon May 23, 2016 12:56 pm
The eyebrow is a reinforcing panel that fits under/inside the top panel and the front edge of the wing...
Ah-ha! Thanks Pippin, that makes more sense, I've consulted an expert on such matters,
and we wouldn't have called that an eyebrow, more of a side brow!
PostPosted: Mon May 23, 2016 2:38 pm
TDC Spares Officer
:lol: :lol: :lol:
PostPosted: Mon May 23, 2016 5:25 pm
I'm not sure I want to know how you consulted him.....
Its not the sort of thing I should be doing....:-)
PostPosted: Mon May 23, 2016 8:27 pm
Standard issue BLMC ouija board, part number SP0666, found it in the glove box next to that "Your passport" booklet, don't you have one? :wink:
PostPosted: Mon May 23, 2016 8:39 pm
TDC Sprint Registrar
I used to have one of those, but traded it in for a direct line to the heavens, BT wired it direct to sod and I can't cancel the contract.
They also wired up the broadband to the netherealm, keeps cutting out.
PostPosted: Mon May 23, 2016 9:14 pm
How about a Rimmers eyebrow cut to match the bit of yours that's rusted and join it at the top to your old one?
Rimmers' eyebrows are approximations, constructed by folding, welding and inserting small sections, whereas the original parts were one-piece pressed panels. Unfortunately, the photos of Rimmers' eyebrows don't make it easy to see how the curved section that runs down the inside of the wing is constructed:
http://www.rimmerbros.co.uk/Item--i-715720P
http://www.rimmerbros.co.uk/Item--i-715719P
Also, buying a Rimmers eyebrow isn't a cheap fix.
PostPosted: Mon May 23, 2016 9:53 pm
These any good for you? have tried to do them in your style......Failing....
I have a pair of them unfortunately they are for the same side. from Mr Ketley at £25 RIP.
Trevor
2008 X-type 2.0D SE
PostPosted: Mon May 23, 2016 10:18 pm
You could use one of these to replace or repair your NS one, or as a template to create a repair panel. Your OS panel may be ok, or if not, you could use one of these to make a reverse template for that side.
PostPosted: Tue May 24, 2016 11:52 am
TDC West Yorks Area Organiser
Trev, Mr Kettley was a weatherman (the same era as the legendary Michael Fish & Ian McCaskill). You are of course referring to the late Brian Kittley who was the Somerset-based triumph speicalist.
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the modern)
2004 Volkswagen Polo Twist (PK54 JYG - a new project car)
"There is only one way to avoid criticsm: do nothing, say nothing and be nothing." Aristotle
PostPosted: Tue May 24, 2016 1:04 pm
...Mr Kettley was a weatherman ...
We know a song about that!
Users browsing this forum: Driftindazza and 1 guest
