It is currently Tue Apr 16, 2024 2:17 pm
Post new topic  Reply to topic  [ 259 posts ]  Go to page Previous 113 14 15 16 17 18 Next
PostPosted: Wed Jul 05, 2017 8:06 pm
You gotta love CAD!
Nice work mate!
PostPosted: Sun Jul 30, 2017 3:42 pm
Today I've dry fitted the front wing with screws and sorted out the inner valance. Welded in the front valance and fitted the headlight mounting plate. Just got the eye brow to finish off on the driver's side and weld the wing on.
PostPosted: Sun Jul 30, 2017 3:48 pm
Last couple of pics from today's work
PostPosted: Sun Jul 30, 2017 9:16 pm
Solid!
PostPosted: Tue Jul 21, 2020 12:08 pm
Site Admin
Site Admin
Welcome to the Forum! Unfortunately the person who started this topic is no longer a forum member and hasn't been on here for nearly three years, so is probably not going to answer your question. However, if you stick around maybe someone else might be able to reply.
PostPosted: Tue Jul 21, 2020 8:12 pm
Last MOT expired 19 Nov 2017
On Sorn.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
480Hrs @ 14/03/2024
Member TDC no 0471
PostPosted: Tue Jul 21, 2020 9:33 pm
There are some pictures of the sump on page 1 of the thread. Maybe someone can identify what sort of is.
PostPosted: Sat Jul 25, 2020 8:43 am
Mazda 323?
https://www.ebay.co.uk/itm/MAZDA-121-II ... SwAHBZ-Eqm
PostPosted: Sat Aug 05, 2023 8:43 pm
So after many years I'm back on to getting the dolomite going. Unfortunately I left it too long sitting on bad ground and the underside has really suffered. I've managed to get the eninge running and checked drive train over and have acquired a new shell to transfer all the parts to. I will keep adding to this thread and hopefully people will keep enjoying it.
PostPosted: Sat Aug 05, 2023 8:49 pm
New and old
PostPosted: Sun Aug 06, 2023 8:32 am
Started to strip donor shell down. Front seats and carpets out. Heater matrix and gearbox tunnel removed. Handbrake lever removed. Front half of wiring loom taken out. Also got most of the parts out of the engine bay. Just clutch master cylinder and insulation to go. There's a small rust hole under where the brake master cylinder is and an on old repair on the throttle pedal mount that's going to need some attention.
PostPosted: Tue Aug 08, 2023 9:33 pm
A bit more progress on the green shell. Got it pressure washed and finished stripping the engine. Git a few holes in the firewall and left hand side behind strut mount. Left hand bonnet mount also needs a repair but apart from that engine bay is pretty solid.
PostPosted: Tue Aug 08, 2023 10:44 pm
That's a real shame given the work you put into it
PostPosted: Wed Aug 09, 2023 5:56 pm
Its just going to be a lot less work to get the green shell repaired than the brown one. It did take me ages to decide to replace the shell as its almost like getting a whole new car with different personality.
PostPosted: Sat Aug 19, 2023 4:51 pm
I've got the front and rear windows out and the chrome off the car without damaging or twisting it so hopefully it will go back on. Only a bit of surface rust around front window. Also put my best boot lid on and adjusted to fit properly.
Users browsing this forum: No registered users and 14 guests
