It is currently Sat Apr 20, 2024 12:33 am
 Post subject: 1959 Morris Oxford
PostPosted: Mon May 16, 2016 8:36 pm
This isn't a Dolomite, but hoping it's ok...
I have owned this car for just over 2 years now. Done various things to it and figured it deserved some form of a log. This thread is being started because I'm just about to undertake some work on it. Driving home today the clutch/gearbox went. Still feels like a clutch but doesn't appear to be disengaging the engine from the box. Also a couple of odd sounds going on. I'm hoping the clutch release bearing/fork is the problem. Time will tell.
:cry:
 Post subject: Re: 1959 Morris Oxford
PostPosted: Mon May 16, 2016 9:11 pm
I've got an insane hankering for a Standard 10, so I can see where you coming from here!
PostPosted: Wed May 18, 2016 12:04 am
I'd certainly give that a home, though it might end up lowered over American racing 5 spokes and powered by SBC!
PostPosted: Wed May 18, 2016 11:39 am
*spits drink all over keyboard*
:shock:
PostPosted: Wed May 18, 2016 12:03 pm
Chapter 1: Clutching at Straws
First problem, I have a Mitsubishi Evo stuck on my lift for the foreseeable future. Going to have to do this the old fashioned way.
Ladies and gentlemen, I present: The old fashioned way! More than a little terrifying getting it up there. Best not go there.
At this point I had a quick poke around with a bore scope. Hard to see what the hell was going on in the bellhousing, which can only be a bad thing.. So, looks like the box is coming out.
Prop off.
Access panels in floor removed.
Box drained, found this in the container, not too shabby for a box this old. Probably means the gearbox survived the clutch buggering up.
Air cleaner (oil filled..) removed from engine, this gives me a bit more room to move the engine about
Exhaust clamp removed for the same reason
Gear lever surround removed, I then undid the 4 bolts in the picutre whilst holding my breath, expecting all manner of ping-f*ckits to leap forth (none did). Note broken contact on reverse light switch - that explains one of the other problems.
I then loosened off the 9 (yes, an odd number) bolts that hold the gearbox cross-memeber on. By this point it was 21:45 and I decided it was probably home time!
PostPosted: Wed May 18, 2016 1:17 pm
:lol: This, every time I even look at a gearbox!
PostPosted: Wed May 18, 2016 7:59 pm
Chapter 2: A Work of Friction
Today was the day I discovered my fate. Luckily, it wasn't anything too terrible.
Loosened off the starter motor and moved it back as far as possible (sadly it hits the oil filter..)
Bellhousing bolts off (except one or two poked through to save my head) and all but two of the crossmember bolts out
Minor shoe repair - zip ties to the rescue
Box out, by this point I'm expecting carnage
Turns out dropping the box onto a tyre and some wood makes it easier to get it out without killing yourself
The problem is..... My friction plate has fallen to bits! £200 for a kit (pressure plate looks a little worse for wear too)
If anyone is really interested, there is a video of me prodding the friction plate ---> HERE <--- . New one is on order, hopefully be here for the weekend (although I'm pretty busy this weekend).
PostPosted: Wed May 18, 2016 9:03 pm
I'm amazed, I expected it to have a column shift. And it has the same double parallel piston master cylinder as my old ZA Magnette which dated from a similar period (56 in my case) though not fitted in the same place.
I have a particular soft spot for station wagons, estate cars, shooting brakes and the like - and this is a particularly fine example of the breed. It would be somewhat sacriligious to customise it,
So I will settle happily for a triumph 2000 estate - with a Turbo'd Skyline 6 pot I think (too many V8 ones about already) Like Jag used to claim for their cars, I like "grace, pace and space" If I ever find one I can afford that ISN'T falling to bits!
PostPosted: Thu May 19, 2016 10:41 am
It always amuses me the way BMC stuff is about 3 times the size of Triumph equivalents in the gearbox department....
There is a fair bit of commonality between those old "Bessies" and Z magnettes....
I'm sure you could find an MGB ish clutch for a lot cheaper....
In fact a complete MGB engine box and back axle would make that go very nicely with a disk front brake job too....
PostPosted: Thu May 19, 2016 6:46 pm
I would imagine this clutch has a coil spring cover and a carbon thrust bearing, my ZA did. I started young, the ZA finished up with an overbored early 3 bearing MGB lump and O/D box but making the front well ZA sump fit the newer block and not leak oil was a nightmare that still haunts me 40 odd years later.
PostPosted: Thu May 19, 2016 7:10 pm
Interesting....
I'm likely to have the same problem sometime in the hopefully not too distant future...
Saw a lovely ZBV at a recent day out with an 18V MGB engine and a type 9 box. Didn't look to shabby with the proper air cleaner
and original ZB carbs I assume....
Not far off my ideal car that....
Users browsing this forum: No registered users and 112 guests
