RUK - Project Recommission 1972 'Dolomite' Auto http://forum.triumphdolomite.co.uk/viewtopic.php?t=32242 |
Page 34 of 55 |
Author: | Karlos [ Wed Aug 30, 2017 6:45 pm ] |
Post subject: | Re: RUK - Project Recommission 1972 'Dolomite' Auto |
RUK? Absolutely! (just kidding) |
Author: | Jon Tilson [ Thu Aug 31, 2017 3:26 pm ] |
If you fit the bottle so the flange is under the bracket and bolts up through it won't that give you enough bonnet clearance? Jonners |
Author: | James467 [ Thu Aug 31, 2017 7:31 pm ] |
Cheers chaps good points, I have adjusted it slightly so it doesn't hit the bonnet now, clearance is tight though. Quote: you have done a neat job fitting the seats,are you going to change the back seat as well
Na, I like the rear seat I'll just leave it. I just couldn't get on with the fronts, plus they wern't a great fit for the car seat.So I have done the big things on the to do list, just some little bits to wrap up now. Recess bonnet, support header tank properly. - Done Remove exhaust and refit fixing manifold blow - Done Carbs - float plug and tune - Tune Tomorrow Set fan cut in. - Done Change oil - Tomorrow Tracking - Possibly Saturday Finish rear brake light - Done Fit new mirrors - Tomorrow Level Headlamps - Tomorrow Give it a run, hopefully Saturday. - Hopefully tomorrow! Phew, nearly there! |
Author: | James467 [ Fri Sep 01, 2017 5:24 pm ] |
Almost ready for TDCIR! Everything is back on and running, I had to reset the dizzy and set the static timing but it runs and sounds very sweet. It needs some fie tuning, I have to pull the choke when I put my foot down but that's just down to the mixture which I have been progressively adjusting. Will give it a run down to Trackerjacks tomorrow morning and see how she goes and a clean in the afternoon ready for Sunday! |
Author: | James467 [ Sat Sep 02, 2017 12:43 pm ] |
Just been to TJ's and back down the A3, she cruised at an indicated 80 faultlessly. I think the mixture could be a little richer, I'll pull the plugs and check this afternoon. I have to admit that I am not convinced about the seats, they are a tad hard for me. I think that the old seats absorbed a lot of vibrations through the shell and these don't because they are harder. They fit nicely though, very comfortable but unless you are on a smooth road it can be a bit like you are sitting on one of those massage chairs! I may swap them for the old ones for tomorrow. The only thing left is to clean her ready for tomorrow. |
Author: | AlanH [ Sat Sep 02, 2017 1:54 pm ] |
Quote: I think the mixture could be a little richer, I'll pull the plugs and check this afternoon
I think you will find that the standard needles are a bit lean. I've just bought some slightly richer ones for mine, not had time to fit them yet.Be careful Dolly autos are addictive, especially 1850s !!! |
Author: | James467 [ Sat Sep 02, 2017 3:01 pm ] |
Quote: Quote: I think the mixture could be a little richer, I'll pull the plugs and check this afternoon
I think you will find that the standard needles are a bit lean. I've just bought some slightly richer ones for mine, not had time to fit them yet.Be careful Dolly autos are addictive, especially 1850s !!! Mine are close to the stops just to get them rich enough, what needles did you get? |
Author: | Jon Tilson [ Wed Sep 06, 2017 9:28 pm ] |
14 BTDC seems a bit too much to me. I think I run mine at about 11 BTDC, but its a TR7 engine with a Sprint dizzie so cant say the curve is really right. Nice job on the rocker cover too. Jonners |
Author: | James467 [ Wed Sep 06, 2017 11:29 pm ] |
Yes factory is 11, but I'm wondering if it had some carbon build up, I think that can cause pinking as well can't it? I have only used V Power in it so a long blast down the M40 could have cleared it out and burnt some rubbish off. Hmmm, will reset to 11 and see what happens. Quote: Nice job on the rocker cover too.
Thanks Jonners, it's Hammerite!
Author: | SprintMWU773V [ Thu Sep 07, 2017 9:04 am ] |
Carbon build up can cause pre-ignition as it can glow and ignite fuel before it's supposed to. |
Author: | Karlos [ Thu Sep 07, 2017 6:12 pm ] |
Carbon build up and over advanced ignition timing are both contributors to pinking. Carbs can't be tuned until the ignition timing is spot on. I always find that what initially seems like a fueling issue is ignition related, everytime.
Author: | James467 [ Sun Sep 10, 2017 6:32 pm ] |
I have reset the timing back to 11 and given it a drive, pinking have definitely stopped now and it feels a lot more peppy so the long run did it a lot of good, in fact its a real pleasure to drive. Have also adjusted the exhaust which has moved as it settled, it's moved slightly again and needs pushing forward as its touching the boot floor slightly I'll do that next weekend as its a bit hot and it just started raining! |
Page 34 of 55 | All times are UTC+01:00 |
