1978 1500hl VVJ http://forum.triumphdolomite.co.uk/viewtopic.php?t=32283 |
Page 2 of 2 |
Author: | dodojoe16 [ Tue Mar 14, 2017 5:55 pm ] |
Post subject: | Re: 1978 1500hl VVJ |
Should it be full with oil ? Going to remove the cable tomorrow and do a bit more digging it see what I can find. Thanks |
Author: | dodojoe16 [ Tue Mar 14, 2017 7:54 pm ] |
Just a picture of my two oldies together. The Land Rover is a long term project. |
Author: | James467 [ Tue Mar 14, 2017 8:14 pm ] |
Quote: Should it be full with oil ?
Yes, sorry just above the tops of the pistons will be fine. Filling it up won't do it any harm!
Author: | dodojoe16 [ Tue Mar 14, 2017 8:40 pm ] |
After looking in there couldn't see any oil although the pistons move up and down very smoothly will top it up in the morning and have a fiddle to see what I can find. |
Author: | Jon Tilson [ Fri Mar 17, 2017 11:01 am ] |
Oil level in SU's should be just below the top of the sliding piston and needs a top up every 1000 miles... I use ATF as its got the same viscosity over a wider temp range. Jonners |
Author: | James467 [ Fri Mar 17, 2017 12:11 pm ] |
Quote: I use ATF as its got the same viscosity over a wider temp range.
Thats a top tip there!
Page 2 of 2 | All times are UTC+01:00 |
