It is currently Wed Nov 14, 2018 3:08 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
 Post subject: Re: VYK The Russet
PostPosted: Mon Jun 18, 2018 5:43 pm
Be interested in how well or not that exhaust down pipe fits,thats the only bit on my exhaust that ive not changed
PostPosted: Wed Jun 20, 2018 12:20 am
I’ll let you know Dave. The angle of the end that meets the middle section looks wrong to me but we will see. Got a few jobs to do before I get to that stage though. Got to dust the welder off....
PostPosted: Wed Jun 20, 2018 7:10 pm
Last weekend i was repairing mine on that end angle,if you havent got rid of your old down pipe yet save it for me
thanks Dave
PostPosted: Thu Jun 21, 2018 4:19 am
I’ll hang on to it for you.
PostPosted: Thu Aug 09, 2018 5:46 pm
It’s a bit tight in here!
It all looks a bit broken at the minute but I’m getting there slowly........
Closer inspection of the drivers floor pan reveals that I don’t need to replace it. Once I had scrapped the bitumin soundproofing stuff off I found that it’s not as bad as I originally thought. I can treat it with a rust killer, and it’s good enough to take a weld when I fit the new chassis leg. Next job is to order the chassis leg from the club and get on with it.
Good news is the the rear subframe mounting bolts came out easily and the subframe drops just enough to give clearance to cut out the old, and fit the new leg. It’s going to be a bit of a squash and a squeeze but I think it’s possible.
The welder is dusted off and ready to go..............
PostPosted: Mon Sep 03, 2018 1:31 pm
Small victory was had today.
I changed the centre bearing on the propshaft with help of the following thread;
viewtopic.php?f=4&t=10078&p=109558&hili ... re#p109558
I got the bearing from Dave Mac propshafts in Coventry. It’s a pretty simple job to split the joint. All you need are some simple tools and a decent sized vice. Though I had a bit of trouble getting the old bearing off. My favourite tool ( propane burner ) came to the rescue yet again providing the heat to break the seal of bearing to shaft, and it then drifted off easily. The rubber boot on mine was in perfect condition so I left it on. If you need to replace the boot I can advise that a boot from a Austin mini inner cv / pot joint, looks like it will fit.
Old
New
Im now waiting for the chassis leg to arrive from Alun and I can get cracking with the welder. :thumbsup:
PostPosted: Fri Sep 07, 2018 4:48 am
If there was a prize for the most boring photo on the forum, then this should surely win it?
The photo reflects perfectly, how boring it is drilling spot welds! I’m going to take myself out into the garden and give myself six of the best for buying yet another car that needs weld repairs...............
PostPosted: Sun Nov 04, 2018 2:28 pm
Some progress has been made - slower than anticipated - but progress all the same. I’ve been snatching the odd hour here and there to work on VYK, but apart from time I’ve found that space to work in has been my biggest challenge.
So the idea was to replace the chassis leg with engine in situ and the rear of the subframe dropped. The plan being, to drill out the old spot welds and cut around the old subframe bolt sleeve from underneath, thus removing the leg but leaving the sleeve in place. Cut the new bolt sleeve off of the new leg and then marry the two together. Old sleeve - new leg. Simple!
I soon found that drilling and cutting the front portion of the chassis leg was pretty much impossible with the engine in place because I just couldn’t get access with the spotweld drill or angle grinder. I think that it could be done if you have smaller air powered tools, but my trusty angle grinder and drill bodies are just too big to fit in the limited space.
Fortunately, only the rear portion of my chassis leg was rotten, with the front portion still in good condition. So, a plan was hatched to splice a portion of the new leg to old...........
As so the new leg was cut to size, zinc primered and drilled for plug welding...
The profile of the new club supplied leg is slightly different but I’m pretty pleased with how it lined up. You can see how I have had to snip the old leg to splay it a little on one corner to get it to line up nicely.
Then it was on to tacks and plugs....
Because I’m limited to the height of the car on axle stands it’s a bit tight under there to get a good welding position but it’s do able, it just slows things down having to rearrange things all the time but I’m getting there ........... :thumbsup:
PostPosted: Sun Nov 04, 2018 3:20 pm
It's coming along nicely, keep the good work up :) :)
1977 Flamenco sprint (VGY NOW TAX AND MOT FREE :D )
