Due to a certain blue 1300fwd I have to get my a*rse in gear and start doing stuff on LD. The interior is superlovely and needs nowt doing apart from a radio putting in... not a priority.
Have removed the o/s front shock (took 10 mins) and will derustify around the inner wheelarch and strut turret. None of it is anything more than just minor surface stuff. I'll chuck the new shock on and that's one side out of the way. Then I'll tackle t'other side.
Once the shocks are done I'll have a gander at the master cylinder (thanks Tony) and check the rest of the system over.
Need to change the temp sensor, thermostat and thermostat housing gasket cos there seems to be a little seepage there. Wiper motor could also do with changing cos it's not always doing as it's told. Oil and filter change needed. Will also change the voltage regulator for an electronic club item, cos I have one lying round. Ahhh! Just wondering if it might be the switch. There's a thought. Hmmm.
Rear number plate light (n/s) not working. Have changed the bulb to no avail. Will check the wiring next. I hate electrics.
All four wheels need cleaning and repainting to look lovely.
o/s sill needs fitting and the front valance needs tidying.... thats it really!! Easy peasy. Needs to be done by mid March..... 2008
