It is currently Fri Apr 19, 2024 2:37 pm
 Post subject: 5 point harness
PostPosted: Sat Feb 27, 2010 8:35 pm
How do you have yours mounted? Particularly the shoulder straps.
 Post subject: Re: 5 point harness
PostPosted: Sat Feb 27, 2010 9:01 pm
My shoulder straps are attached to the rear seat belt mouting points, crossing over each other on the way). The lap straps attach to the front belt lower mounting points. I only have 4 point belts (so far).
David
PostPosted: Sat Feb 27, 2010 9:09 pm
I only have 3 point harnesses. :snivel:
1997 TVR Chimaera 450
PostPosted: Sat Feb 27, 2010 9:57 pm
David
That's how I'd do it, unless you have a harness bar on your cage? (I'm assuming that you have a cage if you're going for 5-points)
I think Lewis posted a diagram ages ago with the various maximum angles for harness straps? Basically the shoulder straps should be as close to horizontal as possible...
Users browsing this forum: No registered users and 19 guests
