It is currently Thu Mar 28, 2024 11:42 pm
Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
 Post subject: Re: Light weight Dolly
PostPosted: Wed Oct 06, 2010 10:23 pm
Guys, where are the weight figures ??
Hans
Can't find where they were posted but have this written down for the boot lid
carbon/kevlar composite boot lid 4kg,
FG one will 5kg
original will weigh 10.5kg.
I can weigh my bonnet for you if you need.
Neil
PostPosted: Fri Oct 08, 2010 2:57 pm
I've just started "playing" with a Spare boot & bonnet. I have the boot down to 9kg. Removed pretty much all the bracing , Man ......heavy compared to the bonnet! Pretty flimsy now though. Should be alright once fitted up. Will see how it goes. Thanks for the replies.
Hi Baz,
Sorry we have no tricks to light weight Dolomites- the category we compete in does not allow the sort of modifications that Hans enjoys.
Philip
Just curious Philip... do your racing Sprints have a traction problem with the rear end on acceleration/under power? If so what have/can be done to assist-short of not accelerating as hard? Already have an LSD?
PostPosted: Sat Oct 09, 2010 12:32 pm
When the car was being run with 9" rims and slicks in Group C spec traction was not an issue- if anything the car needed more power to get the best from the tyres! On the 7 " rims with 205 A048 wheel spin is much easier to induce, but the trick is to get the ride height right front to rear, not use too high a spring rate, and make sure the LSD is set with high torque load,
Philip
PostPosted: Sun Oct 10, 2010 1:00 pm
Thanks Philip !
More work on the boot today- found a substantial amount of bog- the entire flat panel where the boot lock attaches was filled to about 1/4 inch! Maybe why boot so heavy !
Users browsing this forum: No registered users and 11 guests
