It is currently Thu Jul 19, 2018 9:07 pm
 Post subject: Fuel out of webers
PostPosted: Sun Jun 14, 2015 3:47 pm
I thought I would put this on here as my issue is only track related.
My road going Sprint seems to leak fuel from the left had weber card at the rubber mount point when using it hard on the track. On the road it seems fine even if on the motorway etc or high revs for shorter periods.
It has 45 DCOEs and a filter king with Facet electric pump. Any suggestions what to look at first ? Floats seem to have a similar gap but not sure if the float is the issue as I assume something is making it over fuel ?
Even keener to resolve in case I get to the Castle Coombe event next week.
 Post subject: Re: Fuel out of webers
PostPosted: Sun Jun 14, 2015 4:27 pm
What mount setup do you have - thackery washers or metal cups/bushes? If thackery make sure the washer gaps are equal and around 0.025" (can't remember the exact tolerance). The gap for the cup washers is 1.5mm.
Leaky pump jets and chokes can also cause it. Try swapping the pump jets over from both carbs and see if the problem moves. And make sure the chokes are fully returned.
Dan Brown
CA18DET Turbo Sprint - 280hp
Toledo Race Car
PostPosted: Wed Jul 08, 2015 10:04 pm
Check that the floats are not punctured, Take them out and shake them.
Dolly Sprint racer 33
81 Dolly Sprint.
TWR Group A Rover Ch no 002 Hepolite.
4 other Sprints mostly for spares
Rover Tomcat race car.
Lotus Elan + 2S
Mitsubishi Legnum.
BMW E46 M3 convertible.
Rover Vitesse SD1 4500 Twin plenum.
Rover Vitesse SD1 twin plenum
Rover Vitesse SD1 twin plenum.
Rover SD1 2000
Rover Vitesse 820 turbo coupe.
Rover SD1 4200 pick up.
MG TF 160 VVC.
MG Express van 160 VVC.
BMW E30 325i Touring.
BMW E12 M535i.
Lotus Cortina Convertible.
E type Jaguar series 1.
Triumph Stag.
MGB Roadster.
VW Transporter Kombi Sportline.
VW Touareg R line
Capri 3.0 Ghia.
Cortina Savage estate.
Chevrolet 28ft camper.
Morris Minor Traveller.
Nissan Navara.
Mercedes 814.
Suzuki 125 Van Van.
+ many more.
PostPosted: Fri Jul 10, 2015 5:27 pm
Not had a chance to look at this yet. Wouldn't punctured floats give me issues all the time, not just on the track ?
As it runs fine on the road it's going to be difficult to resolve and test without going on the track again but I don't want to risk screwing up a track day with problems on the first run. I have enough issues getting it through noise control :oops:
cron
