poly bushes
poly bushes
Postby IncaSprint1980 on Wed Jul 28, 2010 9:33 pm
i have just bought a poly bush kit, which has a poly bush for the lower wishbone inner balljoints/bush. i know its a metal bush at the moment. has anybody changed the metal bush for a poly bush or is it possible to swap it for a poly bush?
many thanks
rgds
chris :D
own a 1980 Inca Yellow Triumph Dolomite Sprint
1970 Triumph Herald 1200
Reguards
Chris
IncaSprint1980
Re: poly bushes
Postby DavePoth on Wed Jul 28, 2010 9:53 pm
I have a poly inner bush, but I haven't driven on it. The deflection on that bush is very minimal though, and the lower wishbone is very hefty, so it shouldn't cause any stress issues.
DavePoth
TDC Events Officer
Re: poly bushes
Postby Reg on Wed Jul 28, 2010 10:22 pm
Hi Chris, I too have changed them to poly. The Superflex make has a 3 year guarantee. The metal ones had to be pressed out, but I used a large nut and bolt with 2 large washers to put the poly's in. Then used a vice to push the stainless tube into the center.. Havn't driven on them yet..will find out soon. 8)
Reg
Re: poly bushes
Postby IncaSprint1980 on Thu Jul 29, 2010 6:00 pm
hi
thanks for the help will try it
just needed to know how and if possible
thanks for your help
rgds
chris
Reguards
Chris
IncaSprint1980
Re: Poly Bushes
Postby IncaSprint1980 on Sat Jul 31, 2010 1:11 pm
hi
Just pushed out old bushes / ball joints on inner lower wishbone. To replace with poly bush. The original bush had cupped washers one either side - Theses appear to not fit the poly bush. Do i need to get 4 flat washers to pack it out either side of bush when assembled in replacement of cups?
please help
rgds
chris
Reguards
Chris
IncaSprint1980
Re: poly bushes
Postby Reg on Sat Jul 31, 2010 1:47 pm
Hi Chris.. No need for the washers, they are only for the bearing type joint to stop grit ect. The poly is slightly wider to compensate for the lack of washers. It will be a nice snug fit..poly bush, insert stainless sleeve, and the job's a good 'un.. :)
Reg
Re: poly bushes
Postby IncaSprint1980 on Sat Jul 31, 2010 5:03 pm
Hi Thanks for the help. I'll let you know what it's like when fitted and the car is back on the road.
Regds
Chris
Reguards
Chris
IncaSprint1980
Return to Dolomite-related [Start here!]
