Its all been said before but I strongly suspect most vendors are supplying the seal made by Baines.
This was advertised on their sight for toledo and 1500 applications. The screen groove is fine for non laminated zebrazone but I'm not convinced
its right for a later laminated one.
Also I found with my Baines seal that it started to split in the screen corners after less that 2 years. I could not therefore recommend i t on that basis unless the rubber formula has changed.
Your mileage may vary....
Not this old chestnut again! Yes the seal everyone is selling probably came from Baines, since they seem to be the only company currently making one.
But here are the FACTS.
There is only one part number (904111) for the screen rubber for ALL Dolomite and Dolomite related cars whether toughened or laminated screen is fitted.
Toughened and laminated screens are the same thickness to within 0.5mm, with the laminated being the slightly thicker of the 2. Measured by me on several screens of both types.
Rubber degrades in storage, especially if not stored correctly (in the dark) Some "new" rubbers may therefore be dead or dying before even being fitted.
During my research, when I was trying to get an alternative supplier, all the suppliers of Baines seals I spoke to, said they had no, or next to no, complaints about them, so were not interested in making or stocking alternatives. So I gave up!
My windscreen man (who specialises in classics and oddball cars) says he has no issue with the Baines seal either.
