Driving my 1500 yesterday, I had to go over a million speedbumps that London councils kindly distribute around the place. On doing so, the rear exhaust mounting split, which in turn caused a blow at the exhaust to manifold gasket. I didn't realise what it was at first, but the car was making grinding/creaking sounds on acceleration/braking up to 15mph. I put on a new mounting rubber, but as I was tightening up the bolts on the exhaust/manifold join, and one of the studs fell out
I've put a bolt on there now, but it's still blowing a fair bit (at least it doesn't sound like a tractor now
However, now the exhaust knocks against the driver-side chassis rail slightly as I go around corners, and occasionally on accelerating. With the gasket replaced and bolted up properly will the exhaust just fall back into position? I've checked the two exhaust mounting rubbers, the rear is new, and the one just forward of the rear axle is still in place. Is there a third up front? I can't really see under there without jacking the car up.
I'm thinking to replace the whole manifold. The flange that meets the exhaust is pretty manky, and the remaining studs are pretty corroded.
1978 Triumph Dolomite Sprint (
project thread)
1966 Volkswagen 1300 (
project thread)
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
