Code:
Here is the photo evidence of just why some sprint
head gaskets are better than others.
Below are the last two gaskets that have failed, after I have to admit, is serious abuse by my driving, so are unlikely to fail in normal usage but are useless when the car is driven at max rpm. The picture also shows a new
Payen gasket I obtained from Robsport even before the first track day because I just knew the
head would fail.
The breach is between No 4 pot and the water jacket in both cases.
This picture shows the No 1 pot is beginning to fail.
These next two pictures shom the difference between a crap
gasket and a good one. It is clear that the metal is thickier and better located on the
Payen one and also has a ridge running right round the bore top, also the
Payen has complete metall between bores on both sides compared with the thin folded over metal on the cheapie.
In conclusion I would not contemplate using the cheapie ever again as its design and manufacture are clearly inferior and until I compared the two types together, I was not aware of WHY the
Payen type is better.
I would also suggest that perhaps machining a very shallow (.05mm deep x 2mm wide) groove just outside the bore area into the
head would trap the
gasket and make it much harder to blow.
What are your opinions guys...............or girls!
