It is currently Fri Apr 19, 2024 11:11 pm
 Post subject: Locking Wheel Nuts
PostPosted: Mon Sep 13, 2010 7:23 pm
OK so here's the problem,
Got locking wheel nuts on all four corners of Dolomite Sprint ('76), got a key with the original supplier and code. The key has two of the four 'blobs' broken off. (None are in the nuts). Supplier no longer exsists. #-o Got one nut off using a mallet and punch. Three more wont budge. Been suggested I weld something on to nut and then try to budge. Or drill existing key and thread in a small iron rod where the 'blobs' should be. Or I can go down the tyre fitter route and see if they can break off. Friend lent me some locking wheel nut removers but I tried to hammer them on and was told they would 'bind' to the nuts but couldn't make them or really see how that was possible, but not sure they were correct anyway. :wary:
Any ideas folks?
 Post subject: Re: Locking Wheel Nuts
PostPosted: Mon Sep 13, 2010 7:31 pm
depending on what type they are can you post a piccy of one of them?
PostPosted: Mon Sep 13, 2010 8:35 pm
you could try drilling down the nut a bit,with care not to hit the threads. then get a decent size cold chisel on it.
craig
PostPosted: Mon Sep 13, 2010 9:36 pm
I had that probllem trying to buy a set of alloys off a maestro in a scrap yard. and no key .Fortuatly i was able to trace the patten and find the mamufacturer in brum .When i got there they said i could have the key foc. :woohoo: But youll have to search for it in a box that had about 200 in it :snivel:
Users browsing this forum: DotBot [Bot], Majestic-12 [Bot] and 85 guests
