Hi folks
Im thinking of getting a set of alloys for my 79 dolly 1300 - but would like to know the PCD and wheel nut sizes (basically the size of wheels that will fit my 1300)
Rob
wheel sizes PCD ?
Re: wheel sizes PCD ?
How about a set of super ultra mega rare Avon Safety Wheels? They're the correct PCD and have the right nuts for your car
viewtopic.php?f=12&t=17681&p=181145#p181145
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
- gmsclassics
Other cars with the same 4 x 3.75” (95.25mm) PCD (Pitch Circle Diameter).
Austin: Marina
Lotus: Elan, Europa, Seven
Triumph: Herald, Spitfire, GT6, Vitesse
MG: Metro, Montego, Maestro, MGF
Formula Ford Racers
You'll also need to look at the offset so the replacement wheels don't sit either too far and and rub on the inner wing or too far out and rub on the guard. The wider the alloy rim you choose and the bigger tyre you fit, the more of a problem this can become. Sprint alloys are 5.5 wide and I wouldn't go wider than this, nor over tyre a 1300 or you'll find it won't be nice to drive. Try to fit something with the same circumference and then it won't affect the speedo reading.
http://www.carbibles.com/tyre_bible.html
is a good reference and tells you all you need to know. On page 4 there is a calculator that compares tyre sizes
Wheel studs can be changed quite easily - you can get bigger ones to fit - so you can always sort that out later to fit the wheels you want.
Geoff
Austin: Marina
Formula Ford Racers
Geoff
