Mart, the tasks so far are.
Welding... 2x Chassis rails and little bit under Brake Master Cylinder.
Polybushes all round
Strip and clean subframe then get the POR15 gear on it
Dismantle rack, check, clean, soft polybush mounts (possibly put a Toledo rack in)
Clean engine bay thoroghly (without fairy liquid
Clean the engine itself thoroughly.
Sort out replacement wiring if needed for lights etc.
Reconn the starter (bitch to change when back in the car?)
New steering gaitors, TRE's, Ball joints.
Heat wrap the exhaust manifold and downpipe possibly
Might -no MUST- split the box away and check the clutch/bearing out
Dave, didn't read the book as me and my welding man just unbolted what we thought was right
We didnt jack it up high enough first off so had to use the crane to get a bit more lift by using the subframe mount points as an anchor
Live and learn eh?
