It is currently Sat Sep 22, 2018 11:24 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Tue Dec 06, 2011 11:56 am
Site Admin
Site Admin
Please use list as a guide only, we are currently in the process of revamping our stock list. More details soon.
This is a list of items which are usually stocked, although we cannot guarantee that everything is in stock all the time. Ordering details at the end of the list below.
Sprint Items
Bodywork - Coachlines Black, Silver, Gold OE Pattern Remanufactured
£28.99
Bodywork - OE Early Sprint Nose Badge ZKC0375 £19.99
Bodywork - OE Late Sprint Boot Badge ZKC3052 £19.99
Braking - Brake Shoes OE £16.99
Braking - Front Brake Hose £8.99
Braking - Load Sensing Valve Seals (Excludes Dust Cover) £6.99
Braking - Servo Reconditioned & Exchange £135.99#
Braking - Servo Surcharge £20.00
Carburetion - Air Filter Hose Support Bracket Uprated £P.O.A
Carburetion - Alloy Carburettor Mounts 1.75" Pair £67.99
Carburetion - Gaskets For 1.75" Alloy Mounts 158871 AUC4279 Pair
£2.79
Carburetion - Alloy Carburettor Mounts 2" Pair £69.99
Carburetion - Gaskets For 2"Alloy Carb AUD4866 (each) £1.29
Carburetion - O’Rings Std For Alloy Mounts Pair £1.99
Carburetion - O’Rings Viton For Alloy Mounts Pair £5.99
Carburetion - SU Air Filter Gasket 158712 JZX1324 £1.39
Carburetion - SU Solid Butterfly 503817 WZX1321 £8.99
Carburetion - SU Std Jet Front AUD9106 GSU422 £16.99
Carburetion - SU Std Jet Rear AUD9105 GSU421 £16.99
Carburetion - SU Waxstat to Std Jet Conversion Linkage (Each) JZX1307
£2.99
Clutch - Gearbox Cross shaft Remanufactured £45.99
Clutch - Master Cylinder Stainless Sleeved £85.00#
Clutch - Seal Kit Slave Cylinder 52235 SSB627 £6.49
Clutch - Slave Cylinder Stainless Sleeved & Std Piston £29.99#
Clutch - Slave Cylinder Stainless Sleeved & Brass Piston£45.99#
Clutch - Slave Cylinder Brass Piston £15.99
Cooling - Bypass Tube Brass Electric Conversion £19.99
Cooling - Bypass Tube Brass Std £19.99
Cooling - Bypass Tube O’Rings Pair £1.99
Cooling - Fanbelt Kenlowe Fan £4.69
Cooling - Fanbelt Standard Fan £4.69
Cooling - Hose Bottom £12.99
Cooling - Hose Heater £7.99
Cooling - Hose Top LH Large £12.99
Cooling - Hose Top RH Small £9.99
Cooling - Thermostat 82 Deg Recommended £4.99
Cooling - Thermostat 88 Deg £4.99
Cooling - Thermostat Gasket £0.59
Cooling - Water Pump Bung - Electric Conversion £29.99
Cooling - Water Pump Bung O’Rings Pair £2.29
Electrical - Alternator Recon No Surcharge £47.99
Engine - Alloy Spark Plug Tubes £59.99
Engine - Stainless Steel Rocker Cover Allen Key Bolts £6.99
Exhaust - Sprint Sports Mounting Bobbin £2.99
Filtration Air Filter £9.99
Filtration Oil Filter Cartridge £4.99
Filtration Oil Filter Spin On £5.99
Gaskets - Headgasket Std AX540 £NCA
Gaskets - Headgasket +.020 Thicker BK760 £NCA
Gaskets - Headgasket Set Std Excludes Valve Guide Oil Seals £ NCA
Gaskets - Inlet Manifold Gasket JA813 £ NCA
Gaskets - Rocker Cover Gasket £ NCA
Gaskets - Sump Gasket JH469 £ NCA
Ignition - Alternative Ignition Set, Leads, Cap R’arm £42.99
Ignition - Alternative Lead Set £31.99
Ignition - Alternative Dist Cap £8.49
Ignition - Alternative R’arm £4.99
Ignition - Distributor Cap OE Pattern Remanufactured £23.99
Ignition - HT Lead Set OE Pattern Remanufactured £32.99
Ignition - R’Arm OE Pattern Remanufactured £21.99
Ignition - Condenser £4.79
Ignition - Points £2.89
Ignition - Rotor Arm (Alternative Fits Original Cap) £8.99
Ignition - Spark Plugs Cool Running OE Spec £6.99
Ignition - Spark Plugs Set Of 4 £8.99
Service - Kit Std Oil Filter, Air Filter, Spark Plugs, Condenser, Points £32.99
1850 Items
Braking - Brake Shoes 76 On £16.99
Braking - Rear Brake Hose £10.29
Carburetion - Alloy Carburettor Mounts UKC4717 Pair £81.99
Carburetion - Gaskets For Alloy Mounts (each) £1.29
Clutch - Master Cylinder Stainless Sleeved £NCA
Clutch - Master Cylinder Std £32.99#
Clutch - Master Cylinder Surcharge £15.00
Clutch - Seal Kit Slave Cylinder 51373 SP4190 £4.49
Clutch - Slave Cylinder Stainless Sleeved & Brass Piston £45.99#
Cooling - Fanbelt Standard Fan £4.99
Cooling - Hose Top LH Large £10.99
Cooling - Thermostat 82 Deg Recommended £4.89
Cooling - Thermostat 88 Deg £4.89
Filtration Air Filter Stromberg Carb (Each x2 Required) £8.99
Filtration Air Filter SU Carb (Each x2 Required) £8.99
Filtration Oil Filter Spin On £5.79
Ignition - Distributor Cap £8.49
Ignition - Points £3.99
Ignition - Rotor Arm £4.99
Ignition - Spark Plugs Set Of 4 £9.99
Service - Kit Std Oil Filter, Air Filter, Spark Plugs, Condenser, Points £41.99
1300 & 1500 Items
Bodywork - Coachlines 1500 SE Silver, OE Pattern Remanufactured
£65.99
Braking - Brake Shoes 1500HL 76 On £16.99
Braking - Wheel Cylinder 1300 £10.99
Braking - Wheel Cylinder 1500 £10.99
Carburetion - Linkage Rod End Connection (Each) £1.99
Clutch - Seal Kit Slave Cyl 1300 & 1500 76 to 81 £4.49
Filtration Oil Filter Spin On £6.79
Filtration Air Filter SU Single £8.99
Filtration Air Filter SU Carb Dolomite (Each x2 Required) £8.99
Filtration Air Filter SU Carb 1500TC (Each x2 Required) £8.99
Ignition - Condenser RWD £4.79
Ignition - Points RWD £2.89
Ignition - Condenser FWD £4.29
Ignition - Points FWD £2.89
Ignition - Distributor Cap £5.49
Ignition - Rotor Arm £2.99
All Categories
Bodywork - Badge Boot Triumph Late ZKC3062 £22.99
Bodywork - Badge Nose Laurel Wreath Late Black & Gold £24.99
Offside outer cill £50.00 delivered £30.00 if collected
Nearside outer cill £50.00 delivered £30.00 if collected
A pair of outer cills are £80.00 delivered, £60.00 if collected
Offside Cill Reinforcer panels £80.00 delivered, £60.00 if collected
Nearside Cill Reinforcer panels £80.00 delivered, £60.00 if collected
A pair of cill reinforcers are £140.00 delivered, £120.00 if collected
Offside inner cill £40.00 delivered, £20.00 if collected.
Nearside inner cill £40.00 delivered, £20.00 if collected
A pair of inner cills are £60.00 delivered, £40.00 if collected.
NS front door repair panel £31.00
OS front door repair panel £31.00
NS rear door repair panel £31.00
OS rear door repair panel £31.00
Due to increase in costs, there is now no discount for orders for
multiple door panels
NS front wing repair £46.00
OS front wing repair £46.00
NS Boot floor repair £72.00
OS Boot floor repair £72.00
NS Chassis leg £85.00
OS chassis leg £85.00
NS front footwell £95.00
OS front footwell £95.00
NS outer headlamp mounting panel £40.00
OS outer headlamp mounting panel £40.00
NS inner front valance repair £52.00
OS inner front valance repair £52.00
NS inner front valance repair (Toledo/Dolomite 1300/Dolomite 1500 non-HL) £52.00
OS inner front valance repair (Toledo/Dolomite 1300/Dolomite 1500 non-HL) £52.00
NS front subframe mounting kit £48.00
OS front subframe mounting kit £48.00
NS outer front valance upper repair (inc bonnet hinge mount) £40.00
OS outer front valance upper repair (inc bonnet hinge mount) £40.00
NS rear wing repair £60.00
OS rear wing repair £60.00
NS rear wing repair (Toledo/1300fwd) £57.50
OS rear wing repair (Toledo/1300fwd) £57.50
NS rear wheel arch strip £28.00
OS rear wheel arch strip £28.00
NS GRP eyebrow £45.00
OS GRP eyebrow £45.00
NS GRP front wing £145.00 (collect price £115.00)
OS GRP front wing £145.00 (collect price £115.00)
GRP full front outer valance £175.00 (collect price £145.00)
1300 FWD front valance £112.00 (collect price £98.00)
GRP transmission tunnel (manual only, Sprint version) £80.00
collected £95.00 delivered
Rear arch front lip £38.00
Braking - Calipers All Models - Single £63.99#
Braking - Calipers All Models – Pair £126.99#
Braking - Master Cyl Single Line Std £85.00#
Braking - Master Cyl Single Line Uprated £75.99#
Braking - Master Cyl Tandem Line Std £105.00#
Braking - Pads All Models £NCA
Braking - Seal Kit Calliper 51561 SP2697 (Single) £5.99
Braking - Seal Kit Master Cyl Tandem £12.99
Braking - Seal Kit Master Cyl Tandem LHD & Early Sprint £9.99
Braking – Seal Kit Master Cyl Single Line £6.49
Braking - Seal Kit Wheel Cyl Rear 1300 76 to 81 £4.49
Braking - Seal Kit Wheel Cyl Rear 1500 76 to 91 51413 SP2369 (Single)
£3.99
Braking - Seal Kit Wheel Cyl Rear 1500 78 on 1850 76 on & Sprint
(Single) £3.99
Braking - Stop Light Switch £5.99
Carburetion - Choke Cable Twist Lock Alternative £7.99
Carburetion - Choke Cable Pull Lock Alternative £7.99
Carburetion - SU Butterfly Splay Screw 108349 AUC1358 £0.89
Carburetion - SU Float Chamber Gasket 511738 AUC8459 £0.99
Carburetion - SU Jet Gland Seal AUD2194 £0.79
Carburetion - SU Jet Adjusting (each) £3.49
Carburetion - SU Choke Cable Connection (Centre Hole) £3.99
Carburetion - SU Choke Cable Connection (End Hole) £3.99
Carburetion – SU Needle Valve Kits WZX1100 (each) £9.79
Clutch - Seal Kit Master Cyl All Models 50515 SP1963 £6.49
Clutch - Seal Kit Slave Cylinder 1850 51373 SP4190 £4.49
Clutch - Seal Kit Slave Cylinder Sprint 52235 SSB627 £6.49
Cooling - Rad Cap 13lb £4.69
Cooling - Rad Cap 15lb (Uprated Alternative) £4.99
Electrical - Alternator Wiring Plug Kit £4.99
Electrical - Flasher Unit Uprated Electronic £16.99
Electrical - Fuses 17/35 Pack 3 £1.29
Electrical - Oil Pressure Switch £5.99
Electrical - Overdrive Gearbox Lever Wires £8.99
Electrical - Thermal Transmitter £8.99
Electrical - Voltage Stabiliser Uprated Electronic £17.99#
Electrical - Washer Pump Alternative £8.99
1500 Starter Motor £100.00 strict exchange policy only
1850 Starter Motor £100.00 strict exchange policy only
Sprint Starter Motor £100.00 strict exchange policy only
Alternators £tba
Steering Rack £55.00 strict exchange policy
Strg & Suspension - Balljoint Gaitors Lower (Each) £2.99
Strg & Suspension - Balljoint Gaitors Upper (Each) £2.99
Strg & Suspension - Balljoint Lower Front LH or RH £45.99#
Strg & Suspension - Balljoint Upper Front LH & RH £45.99#
Strg & Suspension - Bush Steering Column Bulkhead £5.99
Strg & Suspension - Steering Rack Gaitors (Each) £5.49
Strg & Suspension - Stub Axles Ford Spec Remanufactured Pair £99.99
Strg & Suspension - Stub Axles Std Spec Remanufactured Pair £99.99
Strg & Suspension - Track Rod End (Each) £10.99
Strg & Suspension - Track Rod End Gaitors (Each) £2.99
Strg & Suspension - Upper Balljoint Overhaul Kit £29.99
Strg & Suspension - Upper Steering Coupling FWD Only - Exchange
£27.99
Strg & Suspension - Wheel Bearing Kit £15.99
Strg & Suspension - Tie Bars Adjustable (Pair) £87.99#
Strg & Suspension - Steering Rack Mounts Polly (Pair) £11.99
Universal - Nyloc Nuts Bag 10 1/4" £1.99
Universal - Nyloc Nuts Bag 10 5/16" £2.19
Universal - Nyloc Nuts Bag 10 3/8" £2.29
Universal - Nyloc Nuts Bag 10 1/2" £2.39
TDC Stainless Steel Exhaust Systems (ORDERING DETAILS FOR THESE SYSTEMS IN MEMBERS-ONLY SECTION)
PRICES LISTED INCLUDE VAT AT 20% & DELIVERY WITHIN THE UK
TRIUMPH 1300 FWD 1966-1970 TH 51, 53, 52 £325.00
TRIUMPH 1300 TC 1966-1970 TH 89, 90, 52 £335.00
TRIUMPH 1500 FWD 1970-1973 TH 137, 138, 139 £315.00
TRIUMPH TOLEDO 1973-1975 TH 103, 179, 162 £310.00
TRIUMPH 1500TC 1973-1976 TH 103, 179, 147 £325.00
TRIUMPH DOLOMITE 1300 1976-1981 TH 103, 179, 175 £330.00
TRIUMPH DOLOMITE 1500/1500HL 1976-1981 TH153, 178, 155 £315.00
TRIUMPH DOLOMITE 1854cc
Man non-overdrive/auto 1972-1975 TH 127, 181, 166 £280.00
Man overdrive 1972-1975 TH 127, 180, 166 £265.00
(Transverse box) 1975-1976 TH 127, 167, 168, 155 £300.00
TRIUMPH DOLOMITE 1850HL 1976-1981 TH 127, 167, 168, 155 £300.00
TRIUMPH DOLOMITE SPRINT std system 1973-1981 TH140, 141, 142, 143 £499.00
SHIPPING
Parts can only be supplied to Triumph Dolomite Club Members. Please Quote your Membership
Number when ordering.
Prices include carriage and packaging to mainland UK locations.
Continental Europe carriage will be charged at 15% of the order value.
Rest Of World carriage will be charged at 25% of the order value.
#Exchange Items – We require your old units to be returned to ensure our reconditioning programme
can operate. The prices quoted include carriage to yourselves. The return carriage cost will need to be
met by the club member.
TO ORDER
Ordering details are in the Members-only section and in Dolly Mixture, the Triumph Dolomite Club's magazine. If you require access to the Members-only sections see this viewtopic.php?f=13&t=20146
Club membership costs just £27 for one year or £50 for two years. See viewtopic.php?f=4&t=2412 for details.
PostPosted: Tue Dec 06, 2011 12:21 pm
Just to add I ordered a Starter Motor from the club only last month. Very satisfied with the speedy delivery, courteous service and quality of the the item.
:thumbsup:
PostPosted: Sat Jun 23, 2012 7:31 am
Got my exhaust through the club and although it took a little longer to arrive than I expected (not the fault of the club) I am infinitetly happy with it...! It looks great, makes the engine sound great and, being stainless steel, will last pretty much indefinitely... Top notch service from top notch people for top notch motors... :wink:
1976 Triumph Toledo 1300
PostPosted: Sun Apr 14, 2013 3:36 pm
By the time I located the folk who now own the press tools for the arch panels they had already re-stocked Rimmers. At the price offered to me we could have undercut Rimmers price by a small margin and of course no VAT buy I saw two down sides to this: 1. Potentially upsetting Rimmers who might then be less inclined to support the Dolomite/the Club and 2. The minimum order the tool holders would accept was 30 pairs which is a not inconsiderable sum and also a large quantity of metal to store.
PostPosted: Tue Dec 01, 2015 4:37 am
I'm on the verge of joining.
I like the idea of receiving a regular magazine and I like what I see in the list of parts the club has. But I'm wondering just what the "regalia" is that is referred to in the "How to join" thread. Shirts, hats, jackets, patches, that sort of thing, I suppose.
Does the club have any way of distinguishing a members car?......sticker/decal.......or whatever you call them in the UK?
Cheers,
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it". HENRY FORD
1915 Ford "T" Speedster (Evangeline), 1921 Ford "T" Tourer (Anastasia), 1955 Zephyr 6 (Purdey), 1975 Dolomite SPRINT (Daisy), & a couple of moderns.
Member #2018011
PostPosted: Mon Dec 14, 2015 8:19 pm
Cheers,
Rob
There is a TDC screen sticker, about the size and shape of the old fashioned dealer stickers that used to adorn the lower rear screen of new cars - which I have chosen to display in the front! It fills the sun gap between the visors!
And yes, regalia is T shirts, hats, jackets stickers, mugs and WHY.
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Sat Oct 14, 2017 7:38 am
Where is collection from and is there any chance of the front valance please
PostPosted: Sat Oct 14, 2017 11:03 am
Collection is from Stourbridge, or the Restoration Show at Stoneliegh on 05/11/17 or from the NEC Show the following week...
There is currently a front valance in stock.
PostPosted: Sat Oct 14, 2017 11:31 am
Thank you, any chance of a piccy of the valance
PostPosted: Sat Oct 14, 2017 11:48 am
If you click on this picture, it enlarges...a bit.
viewtopic.php?f=4&t=31388
If you search on 'front valance' you're sure to see testimonials to the quality.
PostPosted: Mon Nov 13, 2017 7:01 pm
Hi again, I will order the valance once my membership is approved (Sent out about a week ago) Is it possible to pay a deposit by PayPal on the valance until the membership arrives. When stripping the front end down in preparation for the valance, I noticed there is a crusty area behind the drivers side headlamp, the munt is sound but the bit above/behind isn't. Is there a repair panel for this please, if so what's it called - Thanks
PostPosted: Mon Nov 13, 2017 7:09 pm
Is the full list of parts at the start of this post still available, and is it an exhaustive list.
Murdo DA :)
TDC Membership No: 2017092
1980 (W) Triumph Dolomite Sprint, Auto, White, 52k miles - ownership by 2 family members since new.
Reg No: RNK 957W
Supplied by Jimmy Metcalfe at Lavender Hill Motors Ltd, Enfield on 30th September 1980
PostPosted: Mon Dec 04, 2017 9:25 pm
No, it is not. Most are not currently stocked!
PostPosted: Tue Dec 05, 2017 12:46 am
How do I go about ordering parts, are the repair panels for the wing bottoms presently available?
Murdo DA :)
Reg No: RNK 957W
PostPosted: Tue Dec 05, 2017 7:17 am
Site Admin
Site Admin
Users browsing this forum: Google [Bot] and 1 guest
