It is currently Thu Apr 25, 2024 3:28 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Mon Jan 04, 2016 5:00 pm
I'm about to fit my third replacement indicator switch on the doly, and wondered if anybody had found a suitable connector to go inside the column shrouding, somewhere near the switch.
I have a brand new switch that I was saving that till I had chance to pull the column and fit the whole thing down to the original connector to the loom. So I've been fitting SH ones bought off eBay. But they're nearly as old and knackered as the one that was buggered when I got the car.
As the latest old one I had has failed, both on indicators and main beam – intermittent contacts and some problem with the auto cancel –, I'm going to have to fit the new one now, without rebuilding the column. So I'm going to have to cut the wires and joining to those already in the column. But is there a connector worth looking at, or is it just splices again?
 Post subject: How about......
PostPosted: Mon Jan 04, 2016 6:16 pm
http://www.carbuildersolutions.com/uk/m ... 6-way-each
This sort of thing?
There are several to choose from....
http://www.carbuildersolutions.com/uk/t ... connectors
If you register with them as a TDC member, Car Builder Solutions give a 10% discount.
Furthermore the last two orders I placed (both over £100) came carriage free :) .
It is worth getting a hold of their catalogue.........
PostPosted: Mon Jan 04, 2016 9:02 pm
Yes Ian, that's the sort of thing. But the question is, is there room under the shrouding for a single connector block, or does it have the be several smaller ones?
PostPosted: Mon Jan 04, 2016 11:49 pm
Why cut the wires???
If you find a tube of the correct diameter you can remove the plastic shroud from the connector pins and then easily feed the wires up and down the column. If you tie a piece of string to the old one before you withdraw it, you then have a draw wire to pull the new one down.
The lid from a Bic biro has a hole the correct diameter to compress the spring on the side of the pin. Just make a diagram of which wire goes to which hole before you disassemble.
I hope you will be fitting relays to your headlights before using the new switch?
PostPosted: Tue Jan 05, 2016 10:15 am
How hard is it to have the column out and do it properly? Takes about 10 minutes...column out that is.
PostPosted: Tue Jan 05, 2016 10:51 am
As a daily drive, I just can't afford the time to rebuild the column right now. I did try taking the column out before, but I didn't want to take the clamp off and I can't get the support prongs past the dash, no matter how I twist it round. I did ask. Anyway, I'd still rather cut the wires than try again. And this idea of pulling the wires through may work for me. I'll have to have a look.
PostPosted: Tue Jan 05, 2016 12:52 pm
If you take the adjusting clamp off, you should be able to dismantle the column enough to get the wire correctly routed. It can be a pig of a job but it shouldn't take too long if you have the right tools to hand. I had to buy a set of pin punches so I could get the pin out. Once the pin is out, the clamp can be easily removed for access to the steering column where the wires are routed. If you're worried about the indicator stalk burning out again then fit relays to the headlights. It is worth doing even if you stick with the sealed beam units. Some contact cleaner might help as well.
PostPosted: Tue Jan 05, 2016 1:48 pm
It does. 10 minutes to change the stalk start to finish.
PostPosted: Tue Jan 05, 2016 5:07 pm
Yep, I always do it this way. Quickest and easiest way.
1997 TVR Chimaera 450
PostPosted: Tue Jan 05, 2016 7:50 pm
One simple way to overcome the difficulties involved in replacing the steering column cables is to remove the plastic sleeve part number 216481. This can easily be removed using a pair of electrical wire side cutters. Once done it will not be missed as the cables are enclose inside the harness cover, part 153813.
PostPosted: Tue Jan 05, 2016 8:30 pm
Is there a picture anywhere of 216481? Rimmers, unusually, was no help.
PostPosted: Tue Jan 05, 2016 9:24 pm
Its the part that you are finding it difficult to get the cables through. The variable length outer sheath /cover. It is not really needed as the cables are held in place / covered by the metal harness cover.
PostPosted: Wed Jan 06, 2016 8:14 am
Well I haven't actually started yet, as I need the car this A.M. and don't want to be halfway through at the time. I hope to start later today or tomorrow, and I'm assuming it's the concetina covering the length adjustment.
PostPosted: Wed Jan 06, 2016 9:38 am
That is the bit.
PostPosted: Wed Jan 06, 2016 10:00 am
Ta. If the rain holds off, I may get to at least look at the job this aft. But the contingency plan involved putting a CD player in the Herald, and it looks like it isn't compatible with the electro-mechanical voltage regulator that goes with the dynamo. So that's another, possibly easier, job.
Users browsing this forum: Google and 19 guests
