The first point to please bear in mind, a properly plumbed cooling system does NOT need an auxiliary pump.
Pumps have have inlet and outlet sides.
On the mechanical type, the bottom hose, heater hose and bypass tube are all on the inlet side of the water pump cover.
Simply placing an electric pump in the bottom hose doesn't work properly at all,
during warm up you have no circulation of coolant (because the thermostat blocks of the flow to the radiator and therefore pump as well).
The pump relies on having a head of water on its inlet side. without such the pump will run dry, shortening its life.
(The heater and bypass are both on the outlet side!)
The only solution is to fit an inline thermostat and replumb the bypass and heater to the bottom hose (i.e., the inlet side).
In Dolly Mixture there have been two EWP conversions written up.
The problems with both are due to incorrect plumbing installation.
Davies, Craig have a very dubious way of disguising this, namely fitting an auxiliary pump, which disguises the problem
and obviously costs you more as they sell you another over priced product. (You are conned into thinking everything
is okay because the heater is working….)
There are (judging by google) hundreds of slant fours and Stag engines running DC installations
but I cannot accept this is even vaguely right.
There is a decent Electric pump available, but it is not sold in the EU, so has to come from the USA
http://www.stewartcomponents.com/index. ... duct_id=70
however Summit Racing sell them on ebay.
