Do these radios have a label on them saying "Positive Earth Only" ? If so there will be some repairs needed. ( Hence the fuse blowing. ) There were also some Mototola and Ekco radios around in the 70's that would be unhappy if there wasn't a loudspeaker connected.
There should be a 2-pin connector which goes to the single loudspeaker mounted at the top of the dashboard. From memory you also needed a 3 ohm loudspeaker to get full power but check the manual.
The single +12 Vpower supply wire should have an in-line noise suppression choke and an in-line fuse ( check the rating in the manual ) which should connect via a bullet connector to the white/ pink wire behind the air-vent.
Supply return was usually via the outer of the coaxial cable from the car aerial. You also need the early type of aerial connector if you have a modern aerial.
If there is a separate earth connector on the metalwork of the radio this goes to a good earth point behind the dashboard.
These sets are jolly good for listening to the Home Service and the Light Programme or the 3rd programme if you like Classical music
HTH,
Thanks Tony. Both radios are negative earth. Never knew a radio can earth through the aerial cable! The aerial lead and connector are compatible and my loudspeaker connector has been extended to two spade connectors. I've located the 12v radio supply so it seems I'm part way there.
I'm more than happy listening to the Home Service, or Radio 4 to use its new-fangled name
Will see if the cassette deck also works as I have a large collection of cassettes!
Still no mention of how to get the radio surround out - do I need to remove the air vent/ choke/ cigar lighter console?
