My 1850 with Lumenition optronic ignition seemed to have an issue with overheating coils. Having run ballasted and unballasted I found the only way to keep my coil cool was to increase the ballast in the system either by running an unballasted coil with a ballast or by a larger than 1.5 ohm resistor on a ballasted coil.
In the end if concerned about hot coil i see no issue with limiting the ignition 12 volt supply with a ballast resistor, my alternator is feeding 14.5 volts via ignition live to the coil, a 1.5 ohm resistor dropped the feed to 11.5, a bit low for an unballasted coil, so a 1 ohm resistor should have got me a very healthy 12-13 volt feed and a luke warm coil. Dont reconnect the cranking 12 volt feed from the starter though as it wont be needed. As its still essentially an unballasted coil just having the 12 volt supply adjusted by an external ballast.
I may still do this myself in the future.
It may be incorrect info from Lumenition that the coil gets hot normally, as there are many knowledgable posters on here who say the coil shouldnt get hot.
Hi Rob, Sorry I didn't answer your question directly. Yes, when I did that posting I did a quick hand-hot temperature measurement of my 12V unballasted ign coil after a trip back along the main road, also with the Lumenition Optronic ignition system in the middle of Winter when it was quite cold outside . Hence my estimation of "just hand hot coil temperature" .
Tomorrow I'll see if I can do the same measurement on the car after some time at idle at , what 22 deg C its been around here today.
And yes, I do like your idea of adding a small amount of resistance externally to the coil. Anything that helps to keep electronic temperatures down while ensuring adequate spark is good.
