dolomite 1300 radiator ducting
toryroger
#1 Post by toryroger »
I have a faint memory of someone organising remanufacture / supply of the 2 pieces of board which guide cold air from grille to radiator?
I tried with Millboard but creased and tore it, but then I had no template to start from .
thanks
toryroger
Re: dolomite 1300 radiator ducting
#2 Post by soe8m »
I did mention a sort of a while ago here or on the good old non official facebook page. My 1300 will receive in 2018 a 2.0 slant engine and do not use mine anymore. I made reproductions in aluminium with a grain on them. But if the ones of a toledo are the same i'm going to re-use these 1300's in that car. That sort of alu sheet must be available in the UK also. Easy to cut with decent scissors and to bend on the side of the table without any tools. It's rigid because of the grain pressed in and I also use this to make the front lower parcel shelf.
These are the ones I did made.
James467
TDC Sprint Registrar
#3 Post by James467 »
The club should have these in stock Roger
toryroger
#4 Post by toryroger »
thanks James
Have sent message
Roger
