Do any of the Dolomite Sprints have a 1/2 - 5/8 inch alloy (looks like zinc-aluminium) spacer between the plate with the throttle linkage cam, etc., and the inlet manifold?
I've discovered I have such a spacer in a carb set-up using a TR7 linkage plate on a Sprint manifold, and I can't find where it came from. I'd always assumed it was off a TR7, but it seems that I may have been wrong about that.
Here's a picture of it between the plate and manifold - the carbs are HS8's but I got them without a manifold or any part of the throttle linkage, so it's nothing to do with them as such.
