Hi All
Does anyone know the distance between the chassis rails at the shock towers? ? I can’t measure mine at the moment, engines in the car.
Thank you
Max
Chassis rails
Chassis rails
Re: Chassis rails
Just measured DTR,
21 3/4" about 55.5cm
Re: Chassis rails
Cheers James
Means I’m goinf to be tight for space if using existing jag engine mounts, they’re about he same width apart
