It is currently Fri Jul 20, 2018 6:59 am
 Post subject: Sprint door lock
PostPosted: Tue Mar 13, 2018 4:43 pm
HELP! The driver's door lock and knob have jammed in the locked position. I can access it via the passenger door, but whatever I try I can't coax the lock to open or the knob to lift. It's happened once before and I managed to persuade it to unlock by depressing the knob slightly while unlocking it with the key. I removed the door panel and lubricated everything, but couldn't see anything physically adrift. It's now happened again but the same trick isn't working now! Ideas please ...
 Post subject: Re: Sprint door lock
PostPosted: Tue Mar 13, 2018 6:37 pm
Sorry, no idea how to help, but you'll get more views (and more replies) if you post this in the main Dolomite-related section of the forum.
Good luck.
PostPosted: Tue Mar 13, 2018 8:17 pm
Ah - I'm new to the Club and thought I was! Thanks for that.
 Post subject: Hmmm.......
PostPosted: Wed Mar 14, 2018 11:46 am
It sounds to me like the lock itself is at fault.
A struggle it will be, but if this is so you will need to remove the door trim panel, which may require the driver's seat
to be removed for access.
Once the trim panel is off, you can disconnect the locking knob's rod from the lock itself
and then manipulate the lock's lugs to unlock the door.
hope this helps,
PS I'll move this to the "Dolomite Related" section...
PostPosted: Wed Mar 14, 2018 12:02 pm
Thanks Ian.
PostPosted: Thu Mar 15, 2018 7:58 pm
I've persevered and have managed to unlock the door!! As I was advised though, I think the lock mechanism is caputt and I'm seeking a serviceable replacement. New ones are listed by Rimmers as 'no longer available' - really helpful - but Fitchetts et al don't even seem to list them, available or not.
In case it's of any interest to anyone in a similar predicament, here's what I did, albeit over a period of three days! Firstly, I squirted fairly liberal amounts of dry lubricant (not WD40 as it accumulates gunge) everywhere I could get the nozzle in - door lock, down the lock knob hole etc and the next day tried pushing/pulling the locking knob while operating the key in the lock. No joy.
Next I went fishing with a bent coat hanger - hoping not to get arrested - while fiddling with the key. Nothing. So more lubricant. Next day I was bloody determined to get back into my Sprint, so I allocated a whole day to the task. I needn't have. 2 minutes' more fishing with the coat hanger until it seemed to have hooked under the link to the door knob, plus a firm turn of the key and a lift of the coat hanger and CLICK!! The damn door was unlocked. Probably not much of a lesson to be learned as the mechanism is clearly knackered and so luck rather than judgment won the day, but I thought it might encourage others! Must remember not to lock it again ...
PostPosted: Thu Mar 15, 2018 9:24 pm
I'm sure I can find you a serviceable drivers door latch mechanism.
I recently acquired a half restored Sprint, 2 doors jammed shut and locked, 1 door needing "persuasion" to unlock or open and one door that didn't fit but did at least open and close.
Lubrication and adjustment solved the sticking N/S/R door, lubrication and persuasion got the O/S/R open and more perseverance got it working properly. I'm rebuilding the unsalvageable O/S/F door which only leaves the N/S/F to deal with.
It seems to be a common-ish problem with cars that are used infrequently, i'm not sure why, maybe something to do with the original grease solidifying and binding everything up. My usual method is to drown everything in WD40 to wash away the old grease and get the door unlocked and open by removing the rods and working the lock and latch bars directly. Then I remove and clean the latch and use white m/cycle chain grease to lube it before refitting.
Hope this helps, Steve
'91 Cavalier 2ltr 8v auto
'95 Cavalier 2ltr 16v auto
PostPosted: Fri Mar 16, 2018 12:00 am
Thanks Steve - I'll pop down and see you!
cron
