It is currently Fri Apr 19, 2024 4:54 pm
 Post subject: Head lamp repair panel
PostPosted: Fri Mar 30, 2018 7:12 pm
Just a Quick question to settle my mind,the club head lamp repair panel,is not big enough to cover the rust I have on the front end of the chassis leg,if I cut out the rust the front end of the chassis leg will be left open,would that give me any alignment problems ?
Thanks Dave
PostPosted: Fri Mar 30, 2018 8:11 pm
It shouldn't give you an alignment problem, i've fitted a couple where this has happened without problems, I usually fit the repair section before cutting away the damaged bit across the front of the leg, then cut out and make up a piece to blank the leg off.
PostPosted: Sat Mar 31, 2018 5:07 pm
second that^^^
Trevor
2017 Jaguar XE R-sport
Users browsing this forum: DotBot [Bot], Google, Trendiction and 53 guests
