It is currently Thu Mar 28, 2024 10:52 am
PostPosted: Tue Apr 24, 2018 5:34 pm
Do you need to have both normal and high-speed settings of the Dolomite windscreen wipers working for the MOT ? It doesn't seem to be mentioned in the .pdf I have, but on the grounds that " If it is fitted, it has to work " do I need the hi-speed setting please ?
Thanks,
PostPosted: Tue Apr 24, 2018 6:30 pm
Hi. Tony I'm an MOT tester of 25 years. Yeah I know groan! Lol nope basically just need to operate on any speed without the need to keep the switch pressed. And hope your mot. Man realises that they don't work that well !
Cheers Dave
PostPosted: Tue Apr 24, 2018 8:59 pm
I have, but on the grounds that " If it is fitted, it has to work "Tony.
No such rule.
PostPosted: Tue Apr 24, 2018 9:28 pm
Cheers Dave
And if he doesn't realise, find yourself a classic friendly tester!
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
PostPosted: Tue Apr 24, 2018 10:38 pm
Cheers Dave
Hi Dave, Thanks for that. It was most useful.
Hey, to use the younger generation's phrase ... Respect ! The MOT Inspector is the professional Referee of the Motor Trade where the Referee of the Football field has the last word on goal / no goal . :)
PostPosted: Wed Apr 25, 2018 10:04 am
No such rule.
You are both right!
There is no universal rule that states this in black and white, BUT, it IS written in to many lesser rules for testable items that have age limits written in, specifically, rear seat belts (before1986), FRONT seat belts (before 1965) rear fog lights (1980) side repeater indicator lights (1984) High level brake lights (1996 IIRC) and quite a few more that my memory hasn't retained!
In all these cases, the items may be fitted to a car that does not NEED to have them to comply with DVSA rules as post production improvements. But if fitted, they BECOME testable items and MUST work!
But the rules on wipers are silent on how many speeds you have. The wipers must clear the screen effectively, be able to be switched on and off without holding the switch and the switch must be clearly labelled (i've had an advisory on this last point, the details of which are irrelevant) There is also no mention of the "self parking" function that most cars have had since the 60s.
Users browsing this forum: AhrefsBot [Bot], Google and 25 guests
